Old 03-07-2012, 01:25 PM   #1
Jonboy
Slots go on anything!
Has anyone used the LH8 pan in their swap?
Like teh title says, has anyone used the LH8 (GMPP Muscle Car swap oil pan) in their LS swap yet? I am getting ready to do a 5.3 swap in my '74, and do a sectioned crossmember at the same time. It is already low, so anyting to help with clearance would be great. I think the 2001 truck pan is going to be waaaay too low. Any thoughts?
1974 Jimmy- 5.3/4L80e/NP241
Old 03-07-2012, 04:15 PM   #2
Indian113
Indian113's Avatar
Re: Has anyone used the LH8 pan in their swap?
I think I will have to when I put my 5.3 in my S10. Have you bought yours yet? I found one for $138.00 + shipping.
Indian113 is offline   Reply With Quote
Old 03-07-2012, 05:34 PM   #3
Jonboy
I went ahead and bought it today. I work at a Chevrolet dealer, but we aren't a GMPP stocking dealer. It wasn't too far off of list, but it will be here tomorrow.
Old 03-07-2012, 10:53 PM   #4
mooseknuckles
mooseknuckles's Avatar
I used one on mine, but it's not in the truck yet so I don't know where it will sit.....but its prob 1 1/2" shorter than the truck pan...I think the f-body pans are lower still....
mooseknuckles is offline   Reply With Quote
Old 03-08-2012, 07:23 PM   #5
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
I have one for mine and it clears the Dropmember fine.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 03-08-2012, 09:25 PM   #6
Notch1988
Notch1988's Avatar
How low does it hang vs the dropmember?
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 03-08-2012, 10:43 PM   #7
BACKYARD88
BACKYARD88's Avatar
If I remember correctly it stays above the Dropmember. I can look tomorrow after work to make sure.
-Mike Owen-
Old 03-09-2012, 12:13 AM   #8
flamingbig10
6.0 powered square
flamingbig10's Avatar
I have one on mine but the pan hangs lower than the cross member
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-09-2012, 12:30 AM   #9
Jonboy
How much lower? I was actually going to go with a sectioned crossmember, too.
Old 03-09-2012, 01:53 AM   #10
72gmcshorty
72gmcshorty's Avatar
You do realize the pan will sit at different levels based on the engine mounts used? It might be more helpful if people told you what mount setup they were using.
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 03-09-2012, 07:34 AM   #11
nibs
JRods Garage
nibs's Avatar
Hmmm, good to know... Is your dropmember the standard or extreme? I wonder if it would make a difference with the fitment
Orange Julius-My dropmember'd, LS'd, SWB street machine...
nibs is offline   Reply With Quote
Old 03-09-2012, 09:40 AM   #12
72gmcshorty
from the info i found, the lh8 pan is a hummer H2 pan. I saw a picture comparing the 2 and they are almost identical in size. If you are looking for clearance, look up a cadillac CTS-V pan. It is a few inches shorter at the crossmember.
1992 Gmc 2wd
Old 03-09-2012, 12:04 PM   #13
BACKYARD88
BACKYARD88's Avatar
I'm not really sure, there was only one when I bought mine lol. It is the 3.2.
-Mike Owen-
Old 03-09-2012, 12:10 PM   #14
nibs
JRods Garage
nibs's Avatar
Ok, I will have to ask ol Nate if this will fit with mine
Old 03-09-2012, 12:30 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I used the GMPP pan as well, with I6 perches and mount adapters. It hangs right at the crossmember level in my 66. It actually looks like its a bit below, but with the suspension at full compression, the crossmember bottoms out before the pan does on something like a big dip in the road.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-09-2012, 01:36 PM   #16
Jonboy
Good call. I am using the Dirty Dingo mounts. I was also concerned with the length of teh sump (the clearance behind the crossmember). The CTS-V pan has a longer (front to back) sump.
Old 03-15-2012, 12:02 PM   #17
BACKYARD88
BACKYARD88's Avatar
Mine is almost dead even with the bottom of the Dropmember.
-Mike Owen-
Old 03-19-2012, 02:01 PM   #18
gringoloco
A guy with a truck
gringoloco's Avatar
Any more updates on this? Would be good to see pics of people's setups with the LH8 pan installed...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-19-2012, 06:52 PM   #19
mooseknuckles
mine....
Old 03-19-2012, 07:26 PM   #20
72gmcshorty
Originally Posted by mooseknuckles View Post
mine....
Is that a truck oil pan? (What's a mooseknuckle anyways...)
1992 Gmc 2wd
Old 03-19-2012, 07:45 PM   #21
mooseknuckles
lol.....lh8/gm muscle car pan...the truck pan is about a 1 1/2" deeper.....
Old 03-29-2012, 09:35 AM   #22
Jonboy
I talked to Brent at Dirty Dingo for a while yesterday. He recommends the F-body pan to ensure adequate clearance. Since I am planning on running a sectioned crossmember, I will need all the clearance I can get. The F-body pan looks to be a bit cheaper than the CTS-V pan also.
Old 03-29-2012, 12:00 PM   #23
68Stepbed
68Stepbed's Avatar
I bought a truck pan for mine, but it hung too low. I ended up going with an F-body pan, and I have much better clearance. Check out my engine swap thread titled "Project: LS1ick68".
I'm using Trans Dapt adapters with POL tubular engine towers.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-29-2012, 08:41 PM   #24
mooseknuckles
buy an f-body one, they are the shallowest ones so far....
Old 03-31-2012, 11:45 PM   #25
BACKYARD88
BACKYARD88's Avatar
I tried to take the pics from a couple different angles. I dont have drop spindles yet so the front isn't laying completely out. The LH8 pan is about 2 1/2 inches deeper than the F-body pan. At the most a tiny sliver of the pan and a small part of the oil plug boss hangs below the Dropmember.
-Mike Owen-
