03-07-2012, 06:50 PM | #1 |
Cab Gas Tank Mount removal ?
I was told the tank mounts can be removed and thrown away,and Id sure like to do that !
Looking for opinions on removal of these gas tank mounts inside the cab. Don't need them any more and I'm wondering if they have any structural purpose to the rear cab,cab in general outside of just holding the tank? Anyone ? Thanks in advance.
Always a place in my heart for old Chevy trucks: My build thread-project truck dream 65" http://67-72chevytrucks.com/vboard/s...d.php?t=510863 |
03-07-2012, 07:41 PM | #2 |
Re: Cab Gas Tank Mount removal ?
I'm in on this one as well. Wondering also if someone used them to mount a cover of some sort to cover up the back of the cab.
Name: Les ---------------------- Couple 80s Couple 70s One 68 |
03-07-2012, 08:05 PM | #3 |
i just used a spot weld cutting bit. took about 10 minutes.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
03-07-2012, 08:12 PM | #4 |
03-07-2012, 09:18 PM | #5 |
Appreciate the reply's,but my question is not so much" how to",but more about "should I".
Im asking this because of structural concern's Thanks, Ed
03-07-2012, 09:47 PM | #6 |
Ken B 60 Chevy Apache 2019 Chevy Silverado Z71 Why buy something when you can build it for twice the price.. Just because something can be done doesn't mean it should be done... |
03-07-2012, 09:49 PM | #7 |
The brackets are not structural, they are only both bolted and spot welded in to provide a secure place to mount the tank. If you would rather have them out there is no reason they need to be there.
03-08-2012, 02:37 AM | #8 |
Hey everyone,dont remove these mounts unless you are working with unfinished body work on the rear cab panel !
I now regret I ever did this.
Always a place in my heart for old Chevy trucks: My build thread-project truck dream 65" http://67-72chevytrucks.com/vboard/s...d.php?t=510863 Last edited by lenguini; 03-08-2012 at 02:37 AM. Reason: spell |
03-08-2012, 04:29 AM | #9 | |
But Found Her 25yrs Later!
I didn't see any reason to tear the whole thing out.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 03-08-2012 at 04:36 AM. |
03-08-2012, 02:01 PM | #10 |
Lenguini please elaborate what went wrong so noone else does this. I'm curious as heck now.
03-08-2012, 03:08 PM | #11 | |
Its near impossible to remove these mounts without drilling through the back of the cab,as I soon found out. One removed last night,when I calm down...Ill do the other. Welding up holes in new body work.....,priceless.
03-08-2012, 06:52 PM | #12 |
Ouch! thanks for the heads up I just ordered a tank from boyd's and will be removing all my old stuff soon hopefully.
03-08-2012, 08:57 PM | #13 |
Sorry to hear about your problem, were you using a drill bit or a spot weld cutter? I removed mine using a spot weld cutter and had no issue going through the cab.
03-08-2012, 09:41 PM | #14 |
i guess i better keep tabs on all this as well
66 LWB/BBW work in progress 68 Camaro SS bigger work in progress 95 Roadmaster Wagon 12.36 @ 107.74 99 Hayabusa 8.72 @ 162 00 Hayabusa 9.33 @ 153 |
03-09-2012, 04:06 PM | #15 |
just a related thought on this.... as I haven't cut mine yet, but...I'm planning on putting 2 small batteries there ( for better temperature/battery life, and weight distribution- using expensive DynaBatt's) as well as stereo amp, etc. Perhaps the tank mounts can be modified for this??
292 + TKO500 |
03-09-2012, 04:18 PM | #16 |
On the 65 trucks,there were 14 spotwelds along the upper portion of each mount.
I wouldn't know about earlier years,so with my experience I'm going to recommend not to do this after bodywork. I used a spot weld cutting bit and it cuts through the back of the panel...period. The first mount removal sent me into orbit I was so pi$$ed off,so I walked away for a day. The solution ...., drill into the mount spot's with the 5/8 spot cutting bit approximately 1/8 of an inch. Do the reminder of the cut with a 3/8 bit that has been ground flat on the end,so find an old bit to do this.You will have to sharpen it as it dulls after 2 or 3 spot weld completions. Pay close attention to your depth,check often.Occasionally pull lightly on the bottom or top of the mount,this will break the spot free if you have drilled deep enough! This procedure works well and does not cut through the back of the cab ! I wish I had figured this out before I started the job...,oh well...now you know !!
03-09-2012, 04:33 PM | #17 |
I just cut off. The tabs that stick out, they kinda seem like nice supports for the floor to back wall. They aren't really in the way.
Posted via Mobile Device |
03-09-2012, 05:02 PM | #18 | |
I saw a few pics of the job, it looked clean and finished so I decided to take mine out. Now that I calmed down from the extra bodywork I have to do..,URG #@*! I'm glad I did it. Cheers, Ed.
03-10-2012, 12:52 AM | #19 |
1 thing at a time is progress.
I left mine thinking I could somehow use them to mount speakers on. I don't know if I ever will, but took the gamble.
Alan
Philippians 2:14-16 |
03-10-2012, 01:31 AM | #20 |
well I was the guy that removed them and it took about ten minutes to get them out.. Ed feel free to post up the pics I sent you..There was not one spot weld on the lower parts of mine. I trimmed them maybe 1/2 under the bottom LEAVING the top part attached to the back wall , using a thin cut off wheel with the 4 1/2 grinder. And flipped the cab mount bolts over filled the extra hole... Man I am sorry to hear that it created extra work.. SORRY!!!
62 long box with a little SBC http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
03-10-2012, 02:44 AM | #21 | |
Anyway,I'm glad I did...it will when done and already now looks like a finished product.I didn't know how I was going to wrap carpet etc. around that garbage,now it will be a snap! Ill give you a call sometime over the weekend.I appreciate all the help. Cheers, Ed.
03-10-2012, 10:40 PM | #22 |
...interesting...I thought they were there for structural support.
Learn something new every day.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
