Old 03-07-2012, 07:25 PM   #1
TwiggyTheDrummer
Keep It Simple Stupid.. Nope..
TwiggyTheDrummer's Avatar
4x4 Help
I have a 1994 Full-Size Blazer with the 4L60E with the dog-leg 4WD shifter mounted on the transfer case. I am able to shift into both 4-High and 4-Low with the indicator light showing, but the front axle does not pull. The actuator is working fine and the fuse is fine. I know that there is a switch on the transfer case also but I have not been able to check it out. There is also a good bit of play in the front drive shaft. Are there any fixes that you guys might know of or any tips?
1963 GMC SWB Fleetside in Sunburst Orange Metallic
305E V6 w/ Plaid VC, Powerglide, BOSS 313 20" Chrome Wheels, Kumho Ecsta STX 275/45/R20's, Alpine/Clarion System, Dynomax Exhaust
Old custom classic trucks have soul. Their dashboards aren't plastic, and they've survived both the best and worst of what the 20th century had to offer. For the owners of these trucks, it's often the same story. Through both good and bad times they persevered, until one day they could turn the key and roll up in a customized truck everyone with good taste would admire.Custom Classic Trucks
TwiggyTheDrummer is offline   Reply With Quote
Old 03-07-2012, 10:20 PM   #2
snj8198
snj8198's Avatar
Re: 4x4 Help
I think there is a vacuum actuated collar on the passanger side axle that slides over to engage the right side stub shaft. They conk out sometimes creating a similar experience you are describing. Everything shows fine but the front just doesn't engage. Have someone shift the t-case in and out while you stick your ear to that junction box and listen for engagement.
Hope that helps. -steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 03-08-2012, 07:59 PM   #3
TwiggyTheDrummer
Re: 4x4 Help
Thanks Steve! I was thinking that it might have been something like that. A buddy of mine owns a 4X4 Custom shop here in town and I think we're going to put it on the lift and give it a ride to see what we can figure out.
