Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 03-07-2012, 08:06 PM   #1
1972k5blazer
wtb a cluch bellcrank block bracket?
I need the bracket that bolts to the block that holds the bellcrank block stud for for the clutch linkage for a 350 ? Anyone got one they can sell , Thanks
1972k5blazer is offline   Reply With Quote
Old 03-07-2012, 09:02 PM   #2
rsavage
rsavage's Avatar
Re: wtb a cluch bellcrank block bracket?
The V8's in my 2WD Suburban and the 4X4 pickup just have the ball screwed into the block on the block side if I remember correctly. I'll double check tomorrow on the 4X4 as the motor would be in the same place as in the Blazer. Both were factory 4 speeds.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 03-07-2012, 09:18 PM   #3
1972k5blazer
okay thank you very much , i thought they just screwed into the block too but looking around on here it looked like some were on a bracket , i was a little confused i about got all my parts bought up to swap my blazer over to the four speed but saw those with the brackets that the ball was on and just thought it screwed into the block so i didnt know if i needed one or what was going on . my block has two holes in it where it looked like one of those brackets would go so it made me think i needed one
Old 03-08-2012, 08:32 AM   #4
rsavage
rsavage's Avatar
I went out and checked the 4X4 this morning. It just has the ball stud in the block. It is located under where the oil dip stick tube goes in the block if that helps.
1961 C1 Corvette
2021 Durango RT 5.7
Old 11-22-2013, 06:46 PM   #5
jjzepplin
jjzepplin's Avatar
Ok so I am also at this point. I tried to screw the ball in the block but the bracket does not line up and the bellcrank (Z-bar) is too long. They are both from a 4x4. I found this on the forum http://67-72chevytrucks.com/vboard/s....php?p=6163996 pic #4. Can I just flip my 4x4 bracket and reposition it and shorten my bellcrank? 72 Blazer ex 4x4. Will post pics tomorrow.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
