Old 03-07-2012, 08:45 PM   #1
aventur1
aventur1's Avatar
Seat Belt Bolt Threads
Are the threads the same for the under the seat belt bolts and the upper corner cab bolts. Going to install over the shoulder belts and need to get bolts and just want to make sure.
1968 4x4 Frame, with a 67 Cab and Bed
A Shorter Step
1999 Dodge 2500 Cummins Diesel
aventur1 is offline   Reply With Quote
Old 03-07-2012, 11:15 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Seat Belt Bolt Threads
I can't tell you the sizes but the ones on the floor are a larger bolt. I would be sure and get grade 8 bolts though.
LockDoc
Leon
Old 03-07-2012, 11:40 PM   #3
aventur1
aventur1's Avatar
Thanks Lock Doc maybe the plastic from the plug is still part in there.
A Shorter Step
