Old 03-08-2012, 09:39 AM   #1
no moa
no moa's Avatar
Vapor canister lines
i was putting my order together for Inline Tube, and i see they have Vapor canister lines. Should i be runnig a vapor canister with the 454? I dont think the 72 had one on it when i got it. I know the 71 does. Not alot of time spent on using them.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 03-08-2012, 11:54 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Vapor canister lines
I did not have the lines hooked up to the vapor canister on my '71 with a 454 and it ran fine.
I just left the vapor canister line hooked up to the tank, but open ended under the truck to allow the tank to vent.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-08-2012, 11:23 PM   #3
stsalvage
Scrapper 1
stsalvage's Avatar
I was told a long time ago the Vapor canister help with gas mileage keeps the tank from pressurizing and it keeps back pressure
stsalvage is offline   Reply With Quote
Old 03-09-2012, 08:52 AM   #4
no moa
no moa's Avatar
I did some reading on it, i guess i should keep it, with the new rear tank, i'll just run a longer line.
Thanks guys
Old 03-10-2012, 10:37 AM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I wonder if that's my problem with poor MPG. I'm hooking it back up!
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-20-2012, 11:53 AM   #6
JCs72C10
Apparently, old school hot rodders say do away with the canisters, and mechanics say keep it because it will aid with MPG.
JCs72C10 is offline   Reply With Quote
Old 03-20-2012, 12:27 PM   #7
69sixpackbee
I was told a long time ago the Vapor canister help with gas mileage....
Uh, okay
69sixpackbee is offline   Reply With Quote
Old 03-20-2012, 12:40 PM   #8
RenoKeene
Florida Edition
RenoKeene's Avatar
Originally Posted by 69 1/2 Six Pack Bee View Post
Uh, okay
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
