Old 03-08-2012, 09:41 AM   #1
ges55
BLACK SATIN
ges55's Avatar
oil pressure shows 60
When I start up my 85 silvo with a 305 up, the gauge goes up to 60 & stays there. Should I get a new sender?
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
Old 03-08-2012, 12:41 PM   #2
GMC Guy
GMC Guy's Avatar
Re: oil pressure shows 60
check all your connections first, especially where the gauge circuit board meets the oil pressure gauge.
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 03-08-2012, 01:07 PM   #3
Hulk Will Smash
Hulk Will Smash's Avatar
I've got a similar issue... Mine is up in the high 40 area under hot idle conditions and under cold conditions or acceleration when hot, the gauge is pegged on the high side. I'm guessing it's a gauge or sender issue... Bu if not I'll let you guys know when it blows!
'87 R30 Crew Cab Dually
It's 11 PM, do you know where your IAC pintle is?
Hulk Will Smash is offline   Reply With Quote
