Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-08-2012, 10:23 AM   #1
F-85
WTB Dana 44 or 60 rear with 3.07 gears
Im looking for a Posi dana 44 or 60 or 63-70 12 bolt with 3.07 gears(or close) for my 65 GMC (leaf). Local would be better but i might be willing to take a road trip or get one shipped. Let me know what you have. Thanks
F-85 is offline   Reply With Quote
Old 03-08-2012, 10:57 AM   #2
F-85
Re: WTB Dana 44 or 60 rear with 3.07 gears
6 lug and for Leaf springs.
Old 03-08-2012, 11:55 PM   #3
Captainfab
60-66 Nut
You will probably have better luck finding a 12 bolt from a '63-'79 K5 or K10 with that gear ratio. It'll bolt right up with the exception of the shocks.
Old 03-09-2012, 12:15 AM   #4
F-85
Same width? I could handle alittle bit slimmer. But any wider and im rubbing.
What will have to be done for the shock mounts?
Old 03-11-2012, 01:19 AM   #5
Captainfab
60-66 Nut
The '63 to early '70 12 bolts are 62" wide, which should be what your current differential measures. The late '70-'82 12 bolts will measure 63-1/2" wide. So one of those obviously won't work for you. Of copurse I would recommend actually measuring the differential you are currently using to verify it's length/width.
Old 03-11-2012, 08:34 AM   #6
F-85
Thanks. Im assuming your saying OD on the width? Ill measure mine today. Thanks
Old 03-11-2012, 05:12 PM   #7
Captainfab
60-66 Nut
Yes, WMS to WMS (Wheel Mounting Surface)
Old 03-11-2012, 06:40 PM   #8
F-85
Cool thank you!
