exhaust ideas and questions
I'm thinking of redoing the exhaust on my truck and would like to do it on my own and not have a shop do it, but I had a couple questions.
I would like it to be loud without sounding like crap, it is not my daily driver so loud Is very good lol. Can I run a 3" pipe from the headers to mufflers and then dump it before the axle? It is 77 c10 with a 350... Thanks!! Posted via Mobile Device |
Re: exhaust ideas and questions
#3 | |
If you are terminating the pipes under the truck before the axle, you will be loud, for sure. Maybe a bit quieter in the truck if you were exiting out either side. I ran a similar system under my old Suburban. Headers to some pipe hung inside the frame rail, a turbo muffler each side, and a turn-down out of the muffler. It sounded really healthy when on the gas, but did produce some resonation in the vehicle. tail pipes would have mellowed it out quite a bit, from what I've heard.
TomS. '98 S-10 Blazer 4dr 4wd - 4.3, AT, stock & '85 K-10 w/ 305, 700r4, np208, and RUST! SOLD Dec 2014 |
I ran dual 3" pipes with flowmaster headers on my 82 C10 with headers. It was quite loud both outside and inside the cab. Sounded great.... but you couldn't sneak around anywhere that is for sure. As a matter of fact my wife could hear me coming home at night when I was still 1/2 mile away from the house.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
i ran 2-1/2 off headers to flowmaster super 10s with turn downs at the rear. and trust me its plenty loud. check out my build i have a vid of it runnin.
i beat tires till they scream for life while the others watch. 2010 nissan titan. wifes truck 1979 dodge magnum e58 police package. wifes baby 1987 chevy short bed. daddys play toy 2002 stratus wifes d.d 2001 dodge 2500 cummins loaded. daddys work truck |
I have duals with glasspacks that dump in front of the rear axle from previous owner and I like the sound. A little loud but not overbearing and doesn't seem to cackle. I think I'm gonna go to duals with Thrush Turbo mufflers whan I redo it. Or maybe run duals into one turbo muffler and a dump. 2 1/2" pipe is plenty big for a small block.
the previous owner of my truck put dual glass packs with headers on it there regular exhaust coming out the rear of the truck not the side before the rear axles though. thats another idea i may incorprate into my truck as well.
Look up "loudest thread" on the search an look at the exhaust thread. Lot of different setups
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
On my 86 with full headers, the drivers side exits straight into the crossmember and I needed to get custom exh made so an "S" pipe to go over it. None of my local custom muffler shops would touch it because they said that because I changed the engine, it did not conform to the factory emissions standards. Summit has a kit # WLK-89007 that fit like a glove. Took me about an hour to install it. I used Thrush welded mufflers. Nice low rumble at idle, and louder than 40 hells when you nail it.
78K & 79C Jimmys
just painted another set of manifolds for the 79
got duals from the 78 burb @2.25 ordered a set of 40 flows ,to slide on the duals from the front
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 03-10-2012 at 11:07 AM. |
| Bookmarks |
