Old 03-08-2012, 03:54 PM   #1
neverwinter
quick question - what master cyl do i need?
hey all
my brother in law is coming over this weekend to help with the disk swap on my 63. i have the entire setup from a 79 ill be swapping to. simple question - what master cyl do i need? 1 inch bore or 1 1/4 in bore (stock for the 63 was a 1 in bore). these are manual brakes not boosted or ower. disks in front / drums in back. according to autozone, rockauto, etc there masters from a 72 are diff from a 73 and up. but i am not sure if i need to match the master to the 63 since that is what its going in (stock pedals etc) but obv need the dual master for the front/rear brakes.
i THINK i need a 1 in bore dual master cylinder. tha seem right?
neverwinter is offline   Reply With Quote
Old 03-08-2012, 10:38 PM   #2
bama63
bama63's Avatar
Re: quick question - what master cyl do i need?
the smaller bore moves the fluid at a higher pressure so no larger than 1 inch bore,the 1 1/4 bore masters are generally for power assisted brakes just make sure you purchase a master cyl for manual brakes and you will be ok fyi i used a 72-76 corvette manual master with 1 inch bore and it was a bolt on hope this helps
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 03-08-2012, 10:49 PM   #3
waspp
waspp's Avatar
I checked out a few corvette master cylinders and when you say it's a bolt on do you mean the bolt pattern on the firewall is the same? My 63 has a bolt pattern that is diagonal and I think the vette master is a horizontal pattern. I don't think its a big deal to redrill the fire wall though.
waspp is offline   Reply With Quote
Old 03-09-2012, 01:21 AM   #4
Captainfab
60-66 Nut
Your '63 has the horizontal mounting holes as well as the diagonal ones. There are a total of 4 bolts/bolt holes around the master cylinder. You will just have to remove the 2 bolts taht are not used right now and place them into the holes for your original master cylinder. All you need is a master cylinder for a '71-'87 truck with manual brakes. It will bolt up to your firewall. As for the pushrod, I can't say for sure if it is the correct length, or if it needs modified.
Old 03-09-2012, 12:14 PM   #5
austin60c10
austin60c10's Avatar
I have a 60 with a hydraulic clutch that I am doing away with and putting a 700r4 in for now would the do you know if the masters you listed above would work for my truck Capt? I plan on staying manual for now and getting your bracket and adding power drums later on.
austin60c10 is offline   Reply With Quote
