Old 03-08-2012, 10:34 PM   #1
michael bustamante
michael bustamante's Avatar
tilt column rebuild Qs
I am wanting to rebuild a tilt column i picked up. its from a 70 4WD but i have no idea where to start. do any of you know of a thread to help me tear it apart and rebuild it
1967custom
michael bustamante is offline   Reply With Quote
Old 03-08-2012, 10:39 PM   #2
jocko
jocko's Avatar
Re: tilt column rebuild Qs
not all-inclusive, but might give you some idear -
http://67-72chevytrucks.com/vboard/s...highlight=tilt
http://67-72chevytrucks.com/vboard/s...d.php?t=329008
http://67-72chevytrucks.com/vboard/s...d.php?t=386933
http://67-72chevytrucks.com/vboard/s...d.php?t=313820
http://67-72chevytrucks.com/vboard/s...d.php?t=194740
Old 03-09-2012, 12:13 AM   #3
jaros44sr
jaros44sr's Avatar
Upper upper, and lower upper bearings are getting hard to find....check with Wes at classic heartbeats, he may have been able to find another set by now.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-09-2012, 10:55 AM   #4
acl
acl's Avatar
I will also say when i did mine the bearings were not to be found. Take care with the tear down. Gary
acl is offline   Reply With Quote
Old 03-09-2012, 12:49 PM   #5
jaros44sr
jaros44sr's Avatar
Service manual is a great source of info., exploded view for reassembly and special tools required, pullers, slide hammer. The two pivot pins can be pulled with a bolt, nut, washer, and a socket of the correct size...
SAFETY FIRST
AS usual, off topic
Jim
Old 03-09-2012, 01:20 PM   #6
michael bustamante
you know thats a good idea. I didnt even think of my 70 chevy service manual.
ill check out those websites now. the bearings still feel good so hopefully I wont have to replace them. I mainly have to tear apart the upper portion where the tilt is to run the turn signal switch wiring. but Im check those bearings for sure now
classic heartbeats.....ill drop wes an e mail
1967custom
Old 03-09-2012, 05:04 PM   #7
jaros44sr
jaros44sr's Avatar
If all you have to do is replace the switch, there is a way to do that without tearing much apart other then the cover
SAFETY FIRST
AS usual, off topic
Jim
