Old 05-03-2003, 09:47 PM   #1
JHickson6
I Love This Stuff!
JHickson6's Avatar
Rust Question?
I was wondering if this rust might be a problem? It seems that there might be rust in between the two layers of metal? Anybody else have this problem? What do you guys suggest to fix it?
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 05-03-2003, 10:28 PM   #2
minibike
minibike's Avatar
That wouldn't be a hard area to cut out and weld in a panel from a donor vehicle. If you are going to use it, blast it and douse it with rust converter or Oshpo, Chemprime, etc.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 05-03-2003, 11:27 PM   #3
gr8scott51
gr8scott51's Avatar
Unless you're building a show truck, scrape and sand and wire bush to remove all of the rust you can, then use a rust killer, a good primer and paint it. It doesn't look terrible. Good luck, Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
