Old 03-08-2012, 10:46 PM   #1
crr26@cox.net
crr26@cox.net's Avatar
sunvisor install
putting my blazer back together and ran into a problem last night. installed the sunvisor brackets on the windshield frame, then went to slide on the actual visors and realized they are too long for the bar that they slide on? ordered them from brothers. not sure if they are different than the truck ones? my other problem is that the little u clip that the bar hooks into is nowhere close to the end of the bar. the bar is supposed to clip in the little hook but the bar is way too short. very confused! please help
crr26@cox.net is offline   Reply With Quote
Old 03-12-2012, 01:47 PM   #2
skidder111
skidder111's Avatar
Re: sunvisor install
crr - the main rod in the visor is right for your application. In the other end of the visor there is an additional short rod (approx. 6") that needs to be installed to fit into the clip. I happen to have mine disassembled for restoration and could get pics if you want.
skidder111 is offline   Reply With Quote
Old 03-12-2012, 10:57 PM   #3
crr26@cox.net
thanks i ended up calling brothers trucks and figured it out. i appreciate it
Old 03-17-2012, 11:56 AM   #4
jcfoote60
Active Member
jcfoote60's Avatar
I just installed a set on mine and have the same problem, the rod is too short. Is this something you bought from Brothers?
jcfoote60 is offline   Reply With Quote
Old 03-17-2012, 01:59 PM   #5
Ole Beater
I think that you can slide the rod out.
Ole Beater is offline   Reply With Quote
Old 03-18-2012, 04:09 PM   #6
jcfoote60
Active Member
jcfoote60's Avatar
Yep that was all I needed to do, go figure! Thanks man
Old 03-18-2012, 07:51 PM   #7
Ole Beater
No problem. Mine was like that for a long time before i figured it out.
Old 03-18-2012, 10:56 PM   #8
crr26@cox.net
i ended up having the 6in rods out of another set of visors, so everything is good now. brothers was very helpfull and sent me pics. they do however sell the little 6in rod seperate if anyone is in need.
