03-09-2012, 12:00 AM | #1 |
aftermarket aluminum rads
anyone using an aftermarket aluminum rad for their LS swap?....what kind?....size?..
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
03-09-2012, 08:01 AM | #2 |
Re: aftermarket aluminum rads
I just bought one from Dave's Truck Parts in NC. I paid $260 for it, and it looks and fits good. I'll post pics when I get them downloaded.
03-09-2012, 08:05 AM | #3 |
I would like to have one with the steam fitting already installed.
03-09-2012, 11:12 AM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
I bought one from Reliable radiators, Champion 3 core aluminum. dual fans ( 12" I think) and it was a direct fit. I should have had a bung drilled for the steam vent but I just went with the upper hose "splice" from Jagsthatrun.com
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-09-2012, 12:14 PM | #5 |
JRods Garage
Very good topic! I was wondering the same
Orange Julius-My dropmember'd, LS'd, SWB street machine... |
03-09-2012, 12:27 PM | #6 |
......do you know the size of it?
03-09-2012, 12:41 PM | #7 |
I'm thinkin of goin with the one in the pic I posted.....it's a Griffin universal unit with the electric fans, and both the inlet and outlet on the right side..I'm not a 100% sure what size I need yet but this one is 31" x19".....
03-09-2012, 01:51 PM | #8 |
JRods Garage
Could you use one thats comparable to the OEM size? I cant say I know the stock size off the top of my head...
03-09-2012, 01:53 PM | #9 |
welll thats what I'm thinkin...31x19 gotta be close...?
03-09-2012, 01:58 PM | #10 |
JRods Garage
do you have a link? I kinda like that one, might have to look into it for my own swap
03-09-2012, 02:00 PM | #11 | |
03-09-2012, 02:53 PM | #12 |
JRods Garage
Not bad really considering the fans come with it too.
Check this guys build... He has a pretty nice alum. rad http://67-72chevytrucks.com/vboard/s...=506692&page=2
03-09-2012, 03:02 PM | #13 |
I was just about to post pics of mine.
03-09-2012, 03:53 PM | #14 |
JRods Garage
Do it anyways!
03-10-2012, 08:00 PM | #15 |
I did a quick measure on my stock rad and the core alone is 28"x18" with the tanks its around 34" wide...so the 31"x19" griffin should fit perfectly...the 45* on the lower rad hose inlet/outlet should help to clear the "Z" as well.....
03-10-2012, 09:13 PM | #16 |
here's mine from entropy... for ls swaps in our trucks....
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
03-10-2012, 09:21 PM | #17 |
nice unit!
03-11-2012, 01:46 PM | #18 |
meowMEOWmeowMEOW
I have a be-cool that was in my truck from back when it had the 355. Single fan, always on, and I'm ok with that.
03-11-2012, 02:49 PM | #19 |
Truck and auto performance nut
I'm running a stock style 4 core with the Old Air Products dual electric fans that were made for our trucks. Low speed fan runs w/key on, high speed comes in if its needed and it all keeps my temp pretty much pegged at 180*
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
03-12-2012, 09:37 AM | #20 |
JRods Garage
Alright, so here is what we have gathered so far... OP, you can edit this into your original post if you would like. Just think it would be a good link for potential and current swappers
Direct Fit(67-72) Entropy Radiators -LSX Swap W/ Fans- $699.00 Reliable Radiator -4 Row Aluminum W/ Fans- $350.00 Dave's Truck Parts -Aluminum Direct Fit W/O Fans- $260 Griffin Thermal -Aluminum LSX Swap Rad-$585.00 via SummitRacing Summit Brand(Northern) -Aluminum 2 core W/O Fans- $299 Universal Fit(Modification Req.) Griffin Thermal -31"x19" Universal Combo W/ Fans- $585 Im sure there are more. If you have a solution that might be helpful, let me know and I can make the changes accordingly! I apologize if this broke a forum rule. I looked through the rules and I didnt see anything regarding anything like this. Jeryd
Orange Julius-My dropmember'd, LS'd, SWB street machine... Last edited by nibs; 03-12-2012 at 11:22 AM. |
03-12-2012, 11:06 AM | #21 |
Here's what I used on two of my swaps:
Summit racing #380457. It is made by Northern (Made in China). I've ordered two and had to send one back because of poor quality control. Anyways, it has a built in 1/2-20 flare fittings for an automatic tranny as well as a 1/4" npt/npsm fitting that I used with a 1/4" barb for the steam vent line. Also, it has a 5/8" heater hose fitting that comes blocked off. It fits perfectly within within the rad support using 4 core mounts. The intake on the driver side is tapered from approx 1 1/4" to 1 3/8"... the stock 5.3 hose slides onto this about half way up. The output is passenger side and also fits the stock 5.3. I believe it is 1 1/2". There is also a nipple at the neck for an overflow. It looks pretty good but it is unpolished. I believe it is a 2 core. If you cross reference this rad it is listed for a '71 chevelle, gto and others. Anyways, I've run it my blazer for the last couple of years. No issues yet. Although, I did recently send one back because it was warped straight out of the box, i.e. poor quality control. It's an easy swap at $299. It is, however, made in China...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 Last edited by OldCreek; 07-12-2012 at 05:46 PM. |
03-12-2012, 01:10 PM | #22 |
I got this one
http://www.ebay.com/itm/GMC-Truck-Al...e84b0a&vxp=mtr Fit very good - with steamport hook-up and used ls hoses
High School Project I ---http://67-72chevytrucks.com/vboard/s...d.php?t=639174 High School Project II ---http://67-72chevytrucks.com/vboard/s...27#post7290427 High School Project III ---http://67-72chevytrucks.com/vboard/s...d.php?t=715832 High School Project IV (Tyler) ---http://67-72chevytrucks.com/vboard/s...d.php?t=780186 |
03-12-2012, 02:05 PM | #23 |
If you end up w/ the griffin that has the inlet,outlet on the pass. side .Heres the Napa hose #'s I used 7096,8295 they fit perfect
03-12-2012, 04:00 PM | #24 |
JRods Garage
you talking about the universal 31x19?
03-12-2012, 09:29 PM | #25 |
thanks for the heads up mac...I ordered the griffin today....
