Old 03-09-2012, 12:52 AM   #1
oldschool18
oldschool18's Avatar
gauge cluster problem
My uncle just bought a 79 K10 and I think he might have a ground problem but I havent looked at it yet. He says his gauges Oil, temp ect. the needles seem to be moving backwards I'm guessing there spinning upside down and he said when he turns on the one turnsignal his highbeam light flashes and when he put the other turnsignal on the other turnsignal flashes and his gas gauge is not working. I gave him an extra ribbon circut for the back of the cluster and it did the same thing. I thought he might have a ground problem but wasnt sure if they changed plugs on the cluster and someone did a swap before they sold it or if anyone had a problem like this.....thanks
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 03-09-2012, 10:29 PM   #2
oldschool18
Re: gauge cluster problem
?????????? I thought for sure someone might have some input??????
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 03-09-2012, 11:41 PM   #3
hatzie
Moderator
hatzie's Avatar
It sounds like someone re-pinned the cluster plug and screwed it up.
Old 03-09-2012, 11:50 PM   #4
oldschool18
that could be........any one got a pic or a diagram of the wiring harness
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 03-10-2012, 12:15 AM   #5
hatzie
Moderator
hatzie's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=456878
Old 03-10-2012, 01:09 AM   #6
oldschool18
Thanks Hatzie it looks like in 82 the big change was there was less grounds and a couple little things like fuel......so if his wiring is right someone might have switched clusters maybe to show lower miles or other one was messed up.....if the wiring change i dont think they changed the gauge just the wire ribbon to the circuts
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 03-10-2012, 10:25 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
i found a spot behind the cluster where the grounds go to one
http://67-72chevytrucks.com/vboard/s...=421767&page=2
post 194 you can see the spot about a foot back from the cluster
and I repinned mine from idiots to gauges if you read it a bit more
and make sure it plugs in good,cause it moving around can make issues
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-14-2012, 12:06 AM   #8
oldschool18
ok my uncle took his dash apart and I went over today to look at it and there was only one wire in the right spot, I went thru the wires by color and checked them against the diagram from above and almost all of the wires where there. I did have two brown wires a yellow and a odd ball pink that did not match the other pink ign. wires...and did not have the blue wire for the oil, looked under the hood and there was a brown wire to the oil sending unit. did not have power to the yellow or pink but didnt check if they might have been a ground for something else thou, had power at the one brown at acc and at on postion and the other brown was just hot when in on postion.......but did get gas,temp, turn signals working he was missing one of the clips for the volt meter and didnt get to check any light had to go to work, but will try some more tomorrow just thought I would chime back in with progress
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 03-14-2012, 06:45 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
my 79
John
Old 03-14-2012, 12:19 PM   #10
oldschool18
Thanks Motornut after I wrote that last nite i did some more research and i got more info....thanks for the help and the pics
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
