Rear wheel fitment
Assuming the right offset, will a 20x12 rear wheel fit between the factory frame rails and still tuck in the box sides?
Raceline billets going on this truck soon. He would like to run the widest rear possible without widening the tubs or narrowing the frame. The rear will come down another inch or two aswell. ![]() ![]()
Instagram @maxh15 #maxhtrucks |
Re: Rear wheel fitment
CANCEL THIS THREAD. Problem solved.
Happy to be here
![]() Join Date: Mar 2000
To answer your question, yes and no. You can do it with out cutting the frame, but not with out wider tubs. Tell him to do a set of those massive 24's on the rear.
The One And Only !!!
Sharp look'n rig as is !
What I'd like to know is what he's got under the hood to need wider than what he's got ?
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
hey,guys i was off for a while but i am back this is a 20x12 they had to narrow the rear end and trim the fender
