Old 03-09-2012, 07:13 PM   #1
realsteelGM
realsteelGM's Avatar
Talking Allignment issues
Recently I believe I must have damaged my driver side steering component from hitting the side of the wheel into a landscape box. The alignment is pretty much dead on, yet the outside of the tire is chaffing and wearing when I make a hard turn to the right.
Anyone have an idea on what happened their? Is it a bent control arm, or other component? Which would be the weakest link?
"gotta love something that works without a computer"
realsteelGM is offline   Reply With Quote
Old 03-09-2012, 07:20 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Allignment issues
I would assume when you say dead on you are saying it doesn't feel bad. I would get it checked. The weak link is probably the tie rod sleeve.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 03-11-2012, 04:38 PM   #3
realsteelGM
The truck had an alignment done to it and it was just about perfect, and yes the tie rod sleeve was damaged, would that be what is causing the outer side of the wheel to chafe?
Old 03-11-2012, 04:46 PM   #4
BMERDOC
BMERDOC's Avatar
Was the alignment done before or after your episode? If it was done after I hope they didn't charge you for an alignment knowing it had a bad part on it. I hope the sleeve took the brunt of the damage. Swap out the sleeve and have it aligned again. If they aligned it after knowing the tie rod was messed up they should do the next one no charge.
Nick Carter
