Old 05-04-2003, 12:30 AM   #1
1968GMC
love my truck
1968GMC's Avatar
problem with temp guage
I instaled a full gauge cluster to relace my dummy light cluster. I'm having truble with my temp gauge, it reads past the H mark, and I instaled a sending unit for gauge. What could it be? Please help.
1968GMC is offline   Reply With Quote
Old 05-04-2003, 12:32 AM   #2
Piston
Piston's Avatar
when you disconnect the sending unit wire at the sending unit, does the gauge move to C? If not you could either have a bad gauge, grounded signal wire (due to installation or pinched/rubbed wire)
Piston is offline   Reply With Quote
Old 05-04-2003, 05:45 AM   #3
Southpa
Southpa's Avatar
This has been discussed alot in this forum and I've had the same problem. I went to mechanical gauge/sensor route instead. But anyway, make sure your ground straps and connections (block to frame, frame to firewall etc.) are intact. And I've also heard that using teflon tape on the sensor might hamper the circuit.
The sensor is the variable resistance variety activated by heat, but you have to have a complete electrical circuit in the system. Take a normally working temp. system and unplug it and you will see the gauge needle peg out to the right. That means infinite resistance, ie. no current. So you might have some grounding problems.
Do an archive search on this site and you will find lots of previous input from other owners to help you out.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 05-04-2003, 10:50 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Look around the exhaust on the drivers side...look for a wire (green if memory serves) that may be melted to the manifold.
Then look on the fire wall where you ran teh wire, see if it is cut and grounding.
If you ground the wire, it'll peg to hot, if there is no ground at all, it'll say cold.
