05-04-2003, 01:14 AM | #1 |
Need help with loud ticking noise
Just got home from work today, and on the way home i start hearing a real loud tapping noise coming from the engine. I pulled the dipstick and saw that the oil is about a half quart low...I just filled er up today...it usually takes about a month to go through that much. I really havent checked much else because it dark and almost 12:30am....So my question is...What happens whenver you blow a head gasket or burn a valve...what are the "symptoms"
thanks for the help...and I really hope this doesnt turn out to be major
1972 Chevrolet C/20 LWB, BB 402, Tach, Bedside Toolbox, Posi, Factory AC, Factory AM/FM, cruise, Dana 60 |
05-04-2003, 02:40 AM | #2 |
Recovering Truck Driver
My guess would be either a collapsed lifter, a broken rocker arm, or a blown exhaust manifold gasket......the all give a pretty good tick.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
05-04-2003, 03:01 AM | #3 |
I would agree...either bad lifter or rocker.
05-04-2003, 04:09 AM | #4 |
former desert rat
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
Same here, or just an exhaust leak?
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const. |
05-04-2003, 10:55 AM | #5 | |
its all about the +6 inches
All are possable, some times you'll only get one of those symptoms. Burning a valve... Intake valve would cause rough running, one dead cylinder above idle. I MAY idle smoth. Back fireing through the carb when ever you touch the throttle. Exhaust valve...pretty much the same as intake except it'll pop out the tail pipe. |
05-04-2003, 11:54 AM | #6 |
3 cheap things to check -
Tighten up the exhaust manifolds. Make sure the fan blades are clearing the shroud. Look at the spark plug wires and dist. cap. Maybe look under the hood at night with the engine running. Maybe you just left your watch under the hood. |
05-04-2003, 11:59 AM | #7 |
Could be a rabbit with a loud thumper.....no help I know.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
