go bucks!
tell me i'm the only one here.....
that notices little things like using shrink tubing on all the electrical leads/ends in the engine compartment. it just makes everything look more neat and orderly in an engine bay. i'm just pet-peevish about little things like that,that finishes off things.guess i'm just weird.....doh!!
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
I'm big on trying to do the little things to make my truck look extra special. My room mate always talks trash cuz I'll do something, and redo it like 6 or 7 times because i always find a neater, or more concealed way to do something. He tends to just throw it together and drive as soon as possible. Thats just not my style.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Recovering Truck Driver
The first thing I do when I look at a truck is check under the hood and the dash and look at the electrical connections.......you have no idea how many times I've seen trucks or cars that just had the wires twisted together.......didn't even bother to buy a roll of tape!! I don't like chasing electrical problems anyway, much less fixing someones hack job.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
I've always been big on shrink tubing. I've had winter road salt eat thru 12 guage wire that was unprotected. Took 2 days to find out why truck would'nt start.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint ______________________________ |
i buy shrink tubing in 25foot rolls find all sorts of uses for it
If you are going to make an electrical connection between two wires, there is only one way IMHO...tin both ends, solder and shrikwrap. You get full continuity out of the wire, and it is protected from the elements. Oh yeah...looks good too!
69 SWB LT1/4L60E www.classicplace.com |
Anybody ever seen soldered connectors? The only ones i've ever found were crimp. Most anyone i ever talked to crimped their wires.
its all about the +6 inches
I use the crimp butt conectors with the heat shring tubing already on them. Kinda expensive, but my boss told be to help myself.
cdowns, where do you get your shrink wrap?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
j.c.whitney has rolls of shrink tube and i also purchase the real premium stuff thats waterproof from a local marina
Guest
Posts: n/a
Low69, what kind of car does your roommate have? A rice burner or something close that will either breakdown or fall apart in a year, where our trucks or still going strong after 35 or so years............
