Old 03-10-2012, 03:12 PM   #1
ooimpalaoo
ooimpalaoo's Avatar
static or air bags?
i have a 1969 gms long box i want to lower...thinking 2.5 drop spindles and 3 inch drop springs for the front...6 inch drop springs and 1.5 inch blocks for the rear...so i would be at 5.5/7.5 if i wend bags instead would i get lower? are they better? i would go on the cheap and have shrader valves for the start...if i go bags do i still need spindles? what are the pros/cons thanx for all the help you guys are great...how low can i get if i dont cup the lower a arms? should i static the front and bag the rear?
ooimpalaoo is offline   Reply With Quote
Old 03-10-2012, 03:17 PM   #2
ooimpalaoo
ooimpalaoo's Avatar
Re: static or air bags?
and if i go bags whats the cheapest place to get them?
Old 03-10-2012, 08:02 PM   #3
SevenOne
SevenOne's Avatar
if you have trailing arms in rear bags are aeasy install.If you have front disk brake already then drop spindles are a great way to get the front lower either way bags/coils.If you got trailing arms then static front and bagged rear sounds like a great start.That way u can tinker with different pressures and ride heigths to get familar with air and where you'd like the truck sit when finished.
SevenOne is offline   Reply With Quote
Old 03-11-2012, 02:17 AM   #4
andrewmp6
Just depends the year truck and can you weld or need a bolt on rear kit?On drop spindles i would buy them either way its the better way to lower the front end.
andrewmp6 is offline   Reply With Quote
Old 03-11-2012, 12:57 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Check with our Forum Vendors for kits. Take a look in our Suspension Marketplace or the Vendors Marketplace for your needs.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
