Old 03-10-2012, 08:44 PM   #1
lytemup454
lytemup454's Avatar
The sound goes away
I just bought an 86 gmc, that had a tape deck in it that didn't work, so I am in the process of changing it out to an Alpine CD player. I have everything wired up using the same wires they had for the tape deck. I checked them against a wiring diagram I had for the truck, and everything seems to match up. My issue is that when I have the radio on and I pull the light switch out the sound goes away. I still have power to the radio I just don't have sound. Once I push the headlight switch in the sound comes back. has anyone ever experienced this before or know where I went wrong?
thanks Ian
lytemup454 is offline   Reply With Quote
Old 03-10-2012, 11:08 PM   #2
Wrecked1982
Wrecked1982's Avatar
Re: The sound goes away
maybe the old radio had a light source maybe its pluged to the wrong wire
Wrecked1982 is offline   Reply With Quote
Old 03-11-2012, 01:34 AM   #3
jhngardner367
jhngardner367's Avatar
The lead for the radio light is,I believe gray.I had the same thing happen,and found that I had mistaken it for a speaker lead.Double-check the wiring,to avoid damage to the speakers/radio.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 03-11-2012, 05:50 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
check with this
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
