BB Trans Cooler - What did you do?
I'm at that point, if I'm going to add it now is the time.
Anyone got time to show me what you did? Mine will be a summer-only driver, and no AC. Did you use GM or aftermarket? Much appreciated! Ron ![]()
69 396BB Turbo 400 Fleetside, 3:07 Gears 2.5" & 4" drop 2020 Silverado 2500LT 2006 Subaru Forester 2019 Chevy Cruze |
Restoration Virgin!
Re: BB Trans Cooler - What did you do?
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Im not to that point yet but I hve thought about it. Id like to do something frame mounted or under the passenger side of the cab. It'll keep the engine compartment cleaner not to mention I dont have to mess with running long lines. It'll have to be fan cooled so my only worry is noise.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
Junior Member
We just buy a trans cooler from a local parts store and then mount it in front of the radiator.
Sorry no pictures.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
I have ran several of the the aux. coolers that go in front of the radiator. In SB trucks they are fine, my big block stuff tends to run warmer than the small blocks, therefore adding heat in front of the radiator in counter productive. I have found the Derale kit from Jegs to be really nice. It comes with mounting brackets that all it to be mounted to the floor and get airflow, as well as a fan. i'm running this setup on my TH350 with a 4000 stall, and having no issue keeping the trans cool.
Ron -
My son is running a trans cooler from Summit Racing for his Big Block '68 with a Turbo 400. It is mounted in front of a Summit aluminum 4 core radiator with 12" electric fans. We have added "Water Wetter" to the coolant to lower the operating temp even more. We purchased a couple of lengths of transmission tubing and bent them to exit just below the radiator core support. We haven't fired the engine yet, but from my experiences with this set up, we should be fine. I hope this helps. NoNeck
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
This is the one I used with stainless braided hose and an fittings mounted in front of radiator made by B&M sorry no pics
Fuzzy |
![]() Join Date: Jan 2010
]I'm using the Derale unit to the right of the radiator.Truck isn't running yet so time will tell if it works.
