03-11-2012, 01:33 PM | #1 |
Crossmember ?
Guys, I am a complete newb to restoring vehicles and I am sorry if this is a stupid question.
But, I have been working on getting my frame all cleaned up for weeks and going through about a billion pictures on here to try and learn as I go. Anyway, I ahve noticed that I never see the Parking Brake crossmember still on the frames. Does anyone reuse it or is it useless once you upgrade the brakes and what not? Thanks, Jay |
03-11-2012, 05:26 PM | #2 | |
60-66 Nut
Re: Crossmember ?
Nope, there are no stupid questions
Well what you have seen can be a number of things. It could be that the truck you have seen is not finished. Also, often times it is because the owner has changed to an auto trans and either is not finished with the installation, or has not figured out how to make the parking brake work with the trans crossmember he used. Another is the fact that starting in '66, GM did away with the crossmember and uses an intermediate cable instaed of the crossmember. A parking/emergency brake is required in some states whether the vehicle has an auto or manual trans. However some guys don't feel the need for one with an auto trans. The need for one does not change with a brake upgrade. Quote:
03-12-2012, 08:16 PM | #3 |
Re: Crossmember ?
Thanks for the info. I took it out to clean it and the frame, I guess I will see if it is needed with my rear disc brake conversion.
Now to just figure out what Trans and trans mount I want in this thing LOL. Jay |
03-12-2012, 09:18 PM | #4 | |
Re: Crossmember ?
03-13-2012, 01:17 AM | #5 |
60-66 Nut
Re: Crossmember ?
You will need to change everything from the cable in the cab, back. There will be an intermediate cable, and different cables that come from each rear wheel. There are also a couple hooks on the frame, as well as a rod and a couple other pieces on the passenger side. This style was used from '66-'72. While I don't care for LMC, they usually have good pics in their catalog that will show the pieces needed.
03-13-2012, 01:37 AM | #6 | |
Re: Crossmember ?
No such things a "Stupid" question. That's how we all learn
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
03-13-2012, 06:22 PM | #7 |
Re: Crossmember ?
HAHA, good because I will most likely blow this site up with questions over the coming months.
Thanks, Jay |
