Old 03-11-2012, 03:17 PM   #1
BIG69GMC
BIG69GMC's Avatar
neutral safety switch?
Hello guys! Wanted to ask if any of u guys have had trouble with a switch that's at the bottom of the steering column, it looks just like a neutral safety switch but my truck is a stick? I have been having issues that resemble a weak battery when I start at times, battery is good and all that jazz. This is a intermittent problem and I was told to replace that switch but wasn't sure wat it was called?
BIG69GMC is offline   Reply With Quote
Old 03-11-2012, 03:25 PM   #2
cdowns
cdowns's Avatar
Re: neutral safety switch?
take off battery cables clean bright and shiny all four endss amd where they mount reinstall with a bit of dielectric grease// see if that helps
Old 03-11-2012, 03:54 PM   #3
BIG69GMC
BIG69GMC's Avatar
Thanks the tip, but I need help regarding the switch that looks like a nuetral safety switch
Old 03-11-2012, 05:16 PM   #4
lil hoodlum
lil hoodlum's Avatar
Some people may say because it is a standard transmission it isn't a Neutral-Safety switch. My truck is a standard transmission and it did have a neutral-safety switch on the base of the steering column. Remember, you truck probably had 3-on-the-tree.
I've replaced mine before. It's not hard to replace. I've got an aftermarket steering column now so it doesn't have a neutral-safety switch.
Keith
lil hoodlum is online now   Reply With Quote
Old 03-11-2012, 05:18 PM   #5
68gmsee
Active Member
68gmsee's Avatar
The reason cdowns mentioned the cable is because your post mentions hard to start. The two are unrelated.
If you suspect the switch, you may be able to bypass it by disconnecting and jumpering the contacts.
Re. hard to start sometimes: Don't overlook the possibility of a bad starter or cables as cdowns mentioned. Cables can also corrode internally at the connector and you can't see it unless you peel back the casing.
Also the starter rotor bushings may be worn or have a flat spot causing the hard to start problem.
68gmsee is offline   Reply With Quote
Old 03-11-2012, 05:22 PM   #6
c1069
c1069's Avatar
Posted via Mobile Devicethis comes from a 3Ott colon and the ones from an automatic have four ends. And I don't think they are called neutral safety switch I think they are for back up lights IMO
Pancho
69 c/10 step side 454/400 with 3.07
c1069 is offline   Reply With Quote
Old 03-11-2012, 05:26 PM   #7
68gmsee
Active Member
68gmsee's Avatar
^ Correct. Forgot to mention that.
Old 03-11-2012, 07:15 PM   #8
BIG69GMC
BIG69GMC's Avatar
Thanks guys, I understand wat u guys mean about basics. Long story short I just put new cables and a battery thinking it was a bad cable. Also new ignition, was just told it could be the switch on the column, but I see now that has nothing to do with starting, only for my lights. It doesn't do it as much but still does it. Well back to the drawing board, thanks guys!! I appreciate all ur input :-)
