Old 03-11-2012, 04:30 PM   #1
Arl37
Gas tank vacuum
69 C10. Is gas tank supposed to be under vacuum when I remove gas cap?
Arl37 is offline   Reply With Quote
Old 03-11-2012, 04:58 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Gas tank vacuum
No it should not be under vacuum your gas cap should be vented
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 03-11-2012, 05:02 PM   #3
lil hoodlum
lil hoodlum's Avatar
Re: Gas tank vacuum
If it helps any, I order and received one from LMC last week. It is a vented one.
Fram part # PRG-23.
I bought two locally one from Oreilys and the other from Car Quest. I told them vented gas cap. Well you guessed it, both were non-venting.
Good luck!
Keith
lil hoodlum is online now   Reply With Quote
Old 03-11-2012, 05:03 PM   #4
dennislbrooks
dennislbrooks's Avatar
Re: Gas tank vacuum
agree -- try a new cap --- happened to my cub lowboy and it would actually run lean and die
dennislbrooks is offline   Reply With Quote
Old 03-11-2012, 06:32 PM   #5
Arl37
Re: Gas tank vacuum
Very interesting. Thank you!
