03-11-2012, 08:35 PM | #1 |
Head Gasket mishap, need opinion
I'm working on my tbi 350 after a blown head gasket. I chased all of the threads in the block and put on the new head gasket. I set on the head and started putting in the new head bolts. I get through the first two torque passes and on the third pass, one of the bolts starts spinning. Basically I stripped the threads in the block some how.
So I figure my only option is to helicoil the block. My question is, do I need a new head gasket? I don't know if it being torqued down will effect it sealing up once I get the threads fixed. |
03-11-2012, 08:57 PM | #2 |
Re: Head Gasket mishap, need opinion
I would replace the head gasket it is not worth doing the job another time.
Fuzzy |
03-11-2012, 09:51 PM | #3 |
I am a Referee of life.
I agree^^
I will ask,did you use a tap to chase the threads?The reason I bring it up is that a tap will recut the threads when used to clean them.It isn't much of a cut(usually) but it can be enough to weaken the threads.A thread cleaner is a much better tool to use.They look like a tap with only 2 flutes and generally wont cut the threads.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-11-2012, 10:05 PM | #4 |
How is the bolt threads, maybe bolt is screwed up. The head gasket will be fine no heat cycle yet. But sounds like a Helicoil is in order, no fun.
03-11-2012, 10:09 PM | #5 | |
03-11-2012, 10:15 PM | #6 | |
Cruzin
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
03-11-2012, 11:34 PM | #7 |
Man I think that truck hates you. I would agree it would probably be best to just buy another head gasket. Sure enough the sob would leak again on ya.
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
