chevy truck fan
ok guys i am trying to figure out how to connect the e-brake cable to the foot pedal on my '72 chevy 2wd truck?
![]() ![]() ![]() can any of you very wise guys give me a hint or two on how to connect it to the pedal arm??? ![]() thanks!!! rodstored-72 |
![]() Join Date: Sep 2010
Re: E-Brake Question ??
How much did you tighten the nut on the equalizer cable? Connect the foot pedal first then the equalizer, if you did that part already. I just finished putting mine back in the Blazer.
chevy truck fan
sorry thriftmaster i do not follow.... the nut/bolt near the firewall is sinched down. but i am unable to connect to the pedal arm (cotterpin part). i tried to do it the other way & i am still short..... i then can not get the bolt bracket to the hole where the bolt goes thru on the pedal assy. .....
![]() Join Date: May 2011
If you climb under the truck you have a small rod hook thing on both sides that acts as a guide for the cable. I popped the drivers side off to give it some slack. Than I reconnected the cable to the lever assy and when all was done it was pretty easy to get that rod hook clip thingy back into the hole in the frame. All is well.
chevy truck fan
Doooh!!!
