New 38s
Looking for info on what is best for the steering options low buck of corse
Posted via Mobile Device |
Re: New 38s
what im asking crossover or go high steer? or dose it make a difference
Too many projects
Re: New 38s
Crossover helps when you lift it more than 4". To fit those 38s you're going to need more than that or some alone time with a sawzall.
Look at Off Road Designs for good service and prices. You can get a junkyard 2WD box to keep the cost down with their components. For better info, we need to know truck specs: Year, type, axles, lift type and amount, etc.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
Re: New 38s
its a 1/2ton 71 GMC 38 tsls 4.56 gears 12bolt rear d44 front 4" lift with 3" body (that i cant stand) its been a while sence it has been operational (12 years).... ill get sum pix up soon
Re: New 38s
quite a few companies that offer cross over or high steer offroad design, north west fab i think and offroad unlimited i run 38.5s with 4in suspension and 3in body no rubbing
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
Re: New 38s
some work done this last weekend
Re: New 38s
do you have any problems with the steering with the body lift?
Re: New 38s
Nope it turned great almost as good as my 03 with 35s but then I put a D60 up front and lost alot of turning although I don't have the common mud truck problem of a huge turn one way and a sharp turn the other way its just equal but not as good maybe one day ill try and fix it
Re: New 38s
Re: New 38s
Dose it put it in a bind at the rag joint
Re: New 38s
No binding issues ill get some pictures possibly within the week
