03-12-2012, 11:49 AM | #1 |
york 210 fittings
Does anyone know a better (cheaper) option to this
I got my pump but it did not come with any fittings, I know I can buy the at kilby but I think 50 big ones is a little much for two fittings Any help is greatly appreciated Posted via Mobile Device
1971 chevy c10 cheyenne. Bagged. New paint and some other mods. 1999 ford f350 superduty 7.3 powerstroke everything banks 1975 c10 swb "parts runner" <----SOLD NorthWest C10's http://www.facebook.com/#!/groups/Norhtwestc10s/ |
03-12-2012, 01:18 PM | #2 |
Re: york 210 fittings
I thought kilby went out of business
03-12-2012, 02:14 PM | #3 |
C10 CLUB Y QUE!
i do... tap the inside.. and use a fitting for it..
maybe i need to inform you a lilttle better. what i did on mine was i had a buddy of mine tap the inside blow hole to give it thread. then i bought elbow and straight fittings for it Last edited by Sick5; 03-12-2012 at 02:16 PM. Reason: more info |
03-12-2012, 02:17 PM | #4 |
Sick5 do you have pics of it done?
03-12-2012, 02:22 PM | #5 |
C10 CLUB Y QUE!
Not any close up shoot. But @ 5 I will post some up for you
03-12-2012, 02:29 PM | #6 |
Thank you
What size are the taps? Do ya remember Posted via Mobile Device
03-12-2012, 08:10 PM | #7 |
Score! Found these at the scrap yard today.
03-12-2012, 08:10 PM | #8 |
Posted via Mobile Device Posted via Mobile Device
03-13-2012, 04:35 PM | #9 |
needs more $$$
If you tap it, shouldn't you use a NPT (or what ever the tapered tap is)?
I bit the bulltet and bought the Kilby's...I don't know if those pieces you scored are going to handle the PSI you're going to fill the tank to with just a barbed end. Maybe I'm wrong here but sometimes $50 is worth a piece of mind.
1970 2wd Blazer |
03-13-2012, 05:36 PM | #10 |
C10 CLUB Y QUE!
I haven't had any issue with mine. Just remember to get 2 oil trappers
03-13-2012, 06:17 PM | #11 |
needs more $$$
Why 2? I only have 1 plumbed in..haven't ran it yet, but didn't plan on running 2 of em.
1970 2wd Blazer |
03-13-2012, 06:45 PM | #12 |
C10 CLUB Y QUE!
York spits out a lot of oil.. and you can't run it dry
03-15-2012, 04:00 PM | #13 |
I traced around those ftgs on a piece of 5/16 steel, cut it on a band saw, drilled holes for it, and then used gasket material. tapped for 3/8 pipe, been running it like that for a couple of years
