Old 03-12-2012, 01:35 PM   #1
RenoKeene
Florida Edition
RenoKeene's Avatar
71-72 throttle cable help
Could one of you 4x4 guys measure your stock cable for me....I need the length from the firewall to where it fits in the carb bracket. I have a stock one from a small block 2wd and it's a little too long for my big block setup. Would like to know if a 4x4 cable would work better.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 03-12-2012, 08:31 PM   #2
coops714x4
coops714x4's Avatar
Re: 71-72 throttle cable help
Reno my 71 4x4 had the same problem, what I did was bend the gas pedal arm to take out the extra slack, that way I could open the 4 barrel up wfo. I am assuming that is your problem also you cant open the carb wide open because of the extra slack ??? Coop
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
Old 03-12-2012, 09:24 PM   #3
RenoKeene
Florida Edition
RenoKeene's Avatar
Hey Coop, no slack, acually works good, the sleeve is just too long between the firewall and the bracket, maybe 1/2" to take the tension off the cable. Gonna have to modify this one.
BTW I will be sporting the shroud you sent me when I roll this thing out.
Old 03-13-2012, 12:09 AM   #4
edhtrd71
Cant help on lengths but I set my sbc against the firewall and had the same issue. You also have ocd. jk. Best fix is to remove the cable cut off the pedal end of cable and pull cable all the way out. Then pull the plastic tube really hard out of the end that attaches to firewall. Cut the tube to desired length and reinstall it in the firewall end. Send the to long cable back through, install it to the truck then cut the cable to length at the pedal. You can use hardware store cable collets to crimp on the pedal end for stop. Hope that helps and probably left stuff out. turns out real nice and you can make sure you can ensure wot.
edhtrd71 is offline   Reply With Quote
Old 03-13-2012, 01:44 AM   #5
coops714x4
coops714x4's Avatar
Ok so you are wanting to take the "slack" out between the firewall and the throttle bracket. is that just for looks or is it causing a problem?
Old 04-18-2015, 12:30 AM   #6
SierraMtns
SierraMtns's Avatar
So your saying you can pull the connector off the hard plastic? It seems like they are fused together.
Anyone know the length of the 4x4 throttle cable?
SierraMtns is offline   Reply With Quote
Old 04-19-2015, 08:28 AM   #7
john@thepier
john@thepier's Avatar
Are reproduction cables for our trucks offered anywhere? Sorry if my question is sort of a hijack of your O.P. John
john@thepier is offline   Reply With Quote
Old 04-19-2015, 01:14 PM   #8
SierraMtns
SierraMtns's Avatar
http://sokyclassics.com/product.php?section=1000825
Old 04-23-2015, 04:06 PM   #9
OrrieG
OrrieG's Avatar
Do not know if this will help but I sold both of the throttle cables off my 74 donor trucks to guys that used them in rods. bolts to the firewall from the cab side, small hole for cable pull action. 74- 80 something will be the same. You should be able to lengthen or shorten the cable using a swag type end terminal, google to see the various applications. I have used them to modify e brake cables. There are fancy tools you can buy to compress them, but I use a 4# hammer and have not had any failures....
OrrieG is offline   Reply With Quote
