Old 03-12-2012, 01:57 PM   #1
88fordf150
88fordf150's Avatar
What do you think, will they work?
Man in the big brown truck dropped me off a set of Speedway Motors Fenderwell Headers. These were for a 55 Chevy but for $204.00 you can't beat the price. I know I am going to have to cut and weld some (too close to the tire and the steering shaft). In the pictures I have the cab sitting on the frame but its not in position, still needs to move forward and down alittle. I think if I cut these at the flange and angle them up a little it will clear both the tire and steering? What do you think? Any suggestions?
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 03-12-2012, 08:26 PM   #2
duallyjams
duallyjams's Avatar
Re: What do you think, will they work?
Convert to rack & pinion steering that will solve the steering problem. If you are using a magneto you could move the engine back some it would be better weight distribution and give you more room for the pulleys.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-13-2012, 08:32 AM   #3
rollinhard
rollinhard's Avatar
Right on. I'm gonna order the same set as this and now know what to expect. Thanks for posting. I think I'm gonna go with a sterring rod with small joints in it to get around the header. And I'm gonna be running a tall deck block with smaller tires so I think ill be ok with out modifying. Keep us posted on your fix. Thanks Curtis
If you can't impress them with your inteligence, dazzle'm with your stupidity
1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe
rollinhard is offline   Reply With Quote
Old 03-14-2012, 07:51 PM   #4
88fordf150
88fordf150's Avatar
I think they are a great deal for $204.00!! If you wait speedway has deals on thier shipping, right now they have $7.00 shipping.
Brad handshoe
Old 03-14-2012, 10:02 PM   #5
crazy longhorn
Fabricate till you "puke"
Right on! Set her back(cut the cab for clearance on the heads /covers)...been there, done that Rack & pinion, or U joints on a Hiem setup should clear the headers? You will love all the setback that you can get, with that blown rat! best of fun,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-14-2012, 11:25 PM   #6
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
boy thats a nice looking steering gear box...
It looks like you have the motor mounts all the way forward? Like the others said I would move it back as far as you can. Then use some steering u joints to get the steering shaft around the headers
Good luck
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 03-15-2012, 05:53 AM   #7
Gokart Mozart
http://www.speedwaymotors.com/Steer-...Drop,6254.html
Steer Clear Steering Box Drop
Finally, a solution to the age old steering column/pedals problem. This nifty box provides unlimited options for steering shaft clearance so a high performance engine and headers will fit. Allows you to safely reposition the steering column higher, giving you more room for your feet and pedals.
Chain driven action
Improved road feel versus typical U-joint setups
Mounts on the inside or outside of your firewall
Four reinforced through-holes assure a strong, secure installation
Uses common 3/4"-36 spline U-joints and couplers
Available in 8", 10", 12", 14" or 16" offsets. Available in brushed or polished finish.
Price: $599.99 - $699.99
Gokart Mozart is offline   Reply With Quote
Old 03-15-2012, 05:07 PM   #8
rollinhard
rollinhard's Avatar
http://www.ebay.ca/itm/New-1955-57-B...#ht_5322wt_886
I wonder if these would be better for fitment. They look like there a little higher. But there also atleast a hundred bucks more. Hopefully your gonna get those fitting in no time
Old 05-11-2012, 08:11 PM   #9
rollinhard
rollinhard's Avatar
Any updates on this setup
Thanks Curtis
Old 05-12-2012, 06:20 PM   #10
88fordf150
88fordf150's Avatar
I think they are the same headers both made by Patriot.
Brad handshoe
Old 05-12-2012, 06:33 PM   #11
88fordf150
88fordf150's Avatar
Well they are not a bolt on and run set of headers. After getting the cab set in the right place and lining everything up, I needed to cut both headers and raise them. The passenger side was sitting right on top of the tire. I split the underside of the header tubes a raised the header until it cleared the steering shaft and was half way between the tire and cab floor. I also ended up cutting about 3" off the collector tube and angled it in toward the frame. I will get them set the way I want them and them take them to be patched and tig welded.
Brad handshoe
