Old 03-12-2012, 06:14 PM   #1
Goldfinger
Goldfinger's Avatar
sway bar question.
I'm Absolutely against the square receivers. For some reason I dislike them. However with a newly acquired airstream I now need an anti-sway bar, well was told i needed. My bumper is rated for 12000lb pull and 1200 tongue. I was curious if i could pull off the spring arms and mount them the the bumper for the same effect.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 03-12-2012, 07:56 PM   #2
beamn7
Re: sway bar question.
Are you talking about the spring arms that are part of a weight distribution hitch? If so, I dont recommend changing it. I'd go with a square receiver and use the weight dist hitch as designed. A anti sway bar for the hitch is another piece of equipment that I would recommend for anything over 22' or so... Maybe a hidden hitch if they bother you that much. I wouldn't sacrafice safety for looks....
Been in the RV industry a number of years and seen a number of accidents from improperly set up hitches....
beamn7 is offline   Reply With Quote
Old 03-12-2012, 07:57 PM   #3
Desert1957
Desert1957's Avatar
WOW, show me some pic's of a step bumper rated that high!
Desert
Desert1957 is offline   Reply With Quote
Old 03-12-2012, 08:14 PM   #4
Goldfinger
Goldfinger's Avatar
Tomorrow afternoon i will. The bumper is a Hercules bumper made in pelham georgia.
Old 03-12-2012, 08:25 PM   #5
Goldfinger
Goldfinger's Avatar
here's whats being pulled
the bumper looks normal but is made pretty stout and bolted to the frame with grade 8 hardware. the stick to the bottom right displays the rating.
sway arm bumper c10 73-87
