![]() Join Date: Feb 2004
1967 4wd shift pattern sticker
Does anyone know the correct location for the 4wd shift pattern sticker for a 1967 K10. I questioned the vendor from whom I bought the shift pattern sticker and all they could say is the driver's compartment. Does it go on top of the driver or passenger visor or in the glove box, or where?
If placed on the ceiling it kinda reads backwards. |
Re: 1967 4wd shift pattern sticker
The one on my moms '70 CST Blazer is on the LH of the glove box door. I could get some measurements tomorrow.
1970 : Chevy: K20 "Frank the Tank" 6.0 LS, 4L80E, 14 bolt, and Dana 44 1970 K5 Blazer CST 350, TH350, Np205, Dana 60 and 14 bolt General Motors Master Certified wrench swinger ASE certified Master auto tech Instructor of Automotive Technology |
BlackhillsHD, I take you mean on the LH side on the outside of the glovebox door?
E.H.F.D Engine #2
I might be wrong, but i think on the 67-68's it was on the roof above the rear view mirror. I know ive seen some up there but not really sure what years. I think 69-70 had them on the glove box door, and 71-72 didnt have them at all. Then again i could be wrong
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
My truck is a custom with the black texture like on the glove box door so not a good place to put it. I am running the correct patterned Ford shifter knob.
If the sticker were reversed it would read correct on the ceiling. Reads 2H 4H N 4L with 2H with stick towards engine. I have tried to find any brochures and searched the web to find where the factory placed. I appreciate everyones responses. Last edited by dennislbrooks; 03-13-2012 at 08:17 AM. |
Is that a ford shifter stick in there?
not the stick, it is homemade but the knob is ford.
Yeah the Blazer is on the LH outside of the glove box door. Doesn't really look like an option for you though.
I believe in 67 the sticker is on the passenger side of the cab, between the rearview mirror and the passenger visor, if it has one. On the 67 cab I have it doesnt have a passenger visor, but the sticker is there, not sure of measurements though....
1969 4x4 Nothing beats a good rock drill and some dynamite |
What?
Here is a photo of a 1967 K10 Suburban xfer case shift pattern sticker.
This is from a un restored burb.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Transfer case shift pattern is the ceiling above the mirror. Lockout hub sticker goes on the left side of the glove box door.
Currently truckless, previous trucks: 67 K20, 87 K10 aka V10 & 72 C10 |
thanks guys, for a 67, I will go with the last 2 posts and others above
#13 | |
BlahBlahBlah
#14 |
Here you go...
#15 |
I need to get that sticker for my 66 k10, what vendor did you get it from?
#16 |
