03-12-2012, 09:00 PM | #1 |
What steering column are you running?
I am getting close to picking out a steering column for the 53. I am thinking about going with a ididit tilt. My buddy says I should just go to the local pick and pull and save money to use else were. So, what column are you running? I have a mustang II.
Posted via Mobile Device |
03-12-2012, 10:23 PM | #2 |
Re: What steering column are you running?
On my '56 sedan, I used an Ididit. It's really nice and I guess you get what you pay for because it was a lot of money but on this truck I'm building, I bought a chrome column from CPP. It was pretty cheap. I'm not driving the truck yet so I don't now how it will do but so far so good.
'59 Big Window Fleetside |
03-12-2012, 10:40 PM | #3 |
I modified my original stock one and kept the original wheel, I like the look of it and to save a couple bucks,
03-13-2012, 12:27 AM | #4 |
I used a tilt column out of a early 70's van, it doesn't have the key in the column so you can keep the key in the dash. It was cheap and looks good with a wooden grant wheel on it. Good luck.
03-13-2012, 04:48 AM | #5 |
I also have a Flaming River Column and steering wheel in my 54. I have a Mustang II set up also. If you go with power steering us a 79-90 Mustang R&P Napa #22-203-F. I have a 74-78 rack right now but it is too sensitive for me. The newer one is less sensitive and provides better road feel. Make sure it is 2 3/4-3 turns lock to lock.
03-13-2012, 12:32 PM | #6 |
I went with a later fullsize van column as I didn't care about key location and wanted all controls on the column. It's a little bulkier than the 70s columns but easier to find. I've seen people use Astro van columns too.
Remember though if it has a column mounted shift, you'll need to work things out if you're putting in an overdrive transmission as the older columns are PRND21. Whether you'll be able to find a good column at your local pull-a-part is what's going to make the difference. Not much point in dropping $50 for a column and then having to spend $$$ to rebuild it all. At that point you might as well get an Ididit or Flaming River. |
03-13-2012, 12:34 PM | #7 |
86 chevy astro /gmc safari column, it's the right length and cost me $35
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
03-13-2012, 01:24 PM | #8 |
74 caprice column shortened to fit rear steer set up i have
03-13-2012, 01:36 PM | #9 |
I went with an Ididit chrome column with a shifter.
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
03-13-2012, 02:52 PM | #10 |
82 Eldorado column, work in progress, trying to figure out how to use another wheel with the telescope without spending $100+ for an adaptor.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
03-13-2012, 04:22 PM | #11 |
oooh, telescope
i wish they still offered them. the seat in my 09 sierra goes all the way back to the rear seat for my legs but the steering wheel is waaaay up there.
03-13-2012, 09:35 PM | #12 |
I have a roadster ididit column.
03-13-2012, 10:08 PM | #13 |
Lot of good options! Choices...
I will have a floor shift also. I like the looks of the flaming river or ididit, simple and clean. The sticker looks good, but my truck didnt come with one and I think tilt would be nice. OrrieG, going with the telescopic sounds.... Comfortable Posted via Mobile Device |
03-14-2012, 12:09 AM | #14 | |
03-14-2012, 08:57 AM | #15 |
Have you looked into a Corvette hub and steering wheel from the 70's
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
03-14-2012, 11:52 AM | #16 |
I'm running a 63 Caddy tilt/ telecopic colum
03-14-2012, 07:25 PM | #17 |
Old Heap Driver
Stock 1950 connected to a S-10 manual box.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
03-16-2012, 06:14 AM | #18 |
What length column did you guys go with?
03-16-2012, 06:00 PM | #19 | |
I'm putting the 63 caddy one in mine to give more room with the 05 silverado seats. not that I need the room (I'm a short a$$) but makes it more sellable if I ever decied to sell it. As far as length goes I'm using a steering link out of a jeep cherokee since they come with u-joints vs rag joints and is spline on the the ps box end and doubleD on the colum end. I cut the shaft to whatever length I needed but never really measured it. |
03-16-2012, 06:16 PM | #20 |
56 - autocross
Going to go with F river. Like that it is stainless.
03-16-2012, 11:40 PM | #21 |
I'm using a 71 Monte Carlo tilt.
Truck's just for the fun of it. |
03-17-2012, 09:09 AM | #22 |
Flaming river for my "49 going to paint to match dash.
03-23-2012, 08:30 PM | #23 |
Youngrodder, Handfull, Fred, what length column do you have?
Thanks Posted via Mobile Device |
03-23-2012, 09:37 PM | #24 |
Wvgearhead,
I used the Flaming River 30" polished column Part #FR20005SS. That is measured from the end of the column to the top of the column that has the tilt part attatched. Then you need an adapter and a steering wheel. My whole set up was over $800. Then you have to get a u joint at the top and bottom and a spline to connect them. I also used a anti vibrate coupling at the point where the coupling meets the steering box. Hopes this helps. |
03-23-2012, 10:35 PM | #25 |
I just got the "old school" column from ididit...$129.00 and it is super simple. have not installed it yet but will post some pics when I get it in.
