Old 03-12-2012, 09:09 PM   #1
502ms
502ms's Avatar
Exclamation Brake Switch and Coil Wiring Questions
Hello guys!
I am wrapping up the installation of my Painless Wire Harness on my 72 C10.
I have also installed Autometer gauges for speedo, tach, fuel, water temp, oil pressure and voltage.
I have two questions:
1) I have the 350 engine, but there is no separate coil. Which wire on the distributor represents the coil for the tach signal? Can you post a picture of which wire coming off the dizzy is the one I need?
2) Where can I find the brake switch? Is it in the cab or under the hood?
I'm sorry for the dumb questions, I have gotten everything pretty much done. It is a rewarding experience, justwant it done right. Thanks!
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 03-12-2012, 09:29 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Brake Switch and Coil Wiring Questions
Originally Posted by 502ms View Post
Hello guys!
The tach terminal is marked on the distributor cap. You may need a flashlight to be able to read it.
The brake light switch is under the dash, between the clutch and brake pedals on manual trans and just to the left of the brake pedal on auto trans trucks.
LockDoc
Leon
Old 03-12-2012, 09:49 PM   #3
502ms
502ms's Avatar
Hi Leon,
Is the brake switch silver, "L" shaped?
I might have removed it...
Best Regards,
Leon M.
