Old 03-12-2012, 09:38 PM   #1
67anthony
Lowering a GMC ?
I have a 67 gmc sb and a 71 chevy long bed parts truck was woundering if the trailing arms would fit to the gmc cross member was wanting 5 lug anyway.
67anthony is offline   Reply With Quote
Old 03-12-2012, 10:51 PM   #2
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Re: Lowering a GMC ?
I'm assuming your GMC is a leaf-spring unit. If so, the arms will bolt right up to your x-member, with the minor exception that you'll need to remove the arm mounts from the chevy cross-member and bolt them onto the GMC (make sure to use grade 8 bolts). You'll also need to to swap over the upper spring mounts and panhard bar frame mount.
I'm in the middle of doing this as well and can say that it's not terribly complicated just some work bustin' out a bunch of rivets.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 03-13-2012, 11:36 AM   #3
67anthony
Thanks man I knew it look like it was the same.
