Old 03-12-2012, 10:59 PM   #1
355bullet
355bullet's Avatar
B&m Light Truck Megashifter
Just installed it couple of weeks ago, works great!
355bullet is offline   Reply With Quote
Old 03-13-2012, 01:53 AM   #2
'79squared
'79squared's Avatar
Re: B&m Light Truck Megashifter
Cant decide if I want one only because I dont like how tall the box is. But they are cool.
1979 SWB 350/350
'79squared is offline   Reply With Quote
Old 03-13-2012, 01:56 AM   #3
Pop's C-10
Pop's C-10's Avatar
nice
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 03-13-2012, 02:00 AM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Not my first choice of shifters but I'm glad to see it works in our trucks. I thought s10 were more what they were geared for hence "light truck". I use lokar in mine direct mount to the trans for a 4on the floor look and a nice right hand rattle
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-13-2012, 02:51 AM   #5
Low84
Low84's Avatar
any pics?
Low84 is offline   Reply With Quote
Old 03-13-2012, 03:00 AM   #6
INSIDIOUS '86
I will try and get some tomarow and start a thread.
Only problem with lokar is the shifters do not have reverse lockout
Old 03-13-2012, 07:09 AM   #7
hotrodimpy
Insidious 86 ALL Lokar shifters have reverse lockout. Our shifters are designed to stop in the netrual position when it is moving from any of the selectable gears. If you are not stopping in netrual when going to the park position from 1,2,D or OD there is most likely an adjustment issue. Please contact our tech department toll free at 1-877-469-7440
We will be happy to try and work with you in trying to get the adjustment worked out.
Thank you John
hotrodimpy is offline   Reply With Quote
Old 03-13-2012, 09:34 AM   #8
bigsj
bigsj's Avatar
what did that shifter coast i have been thinking about getting one.
bigsj is offline   Reply With Quote
Old 03-13-2012, 10:22 AM   #9
Stepper562
Stepper562's Avatar
Thank you John
I second that...adjustment issue. I just installed a 16' on my th400. On the first test drive there was no lock out then I fiddled with the knob and lock out cable and voila...100%. Give them a ring, they'll walk you through. Great service.
Stepper562 is offline   Reply With Quote
Old 03-13-2012, 10:45 AM   #10
355bullet
355bullet's Avatar
Thanks guys!
Shifter runs about 200bucks from summit racing.com
Lokar has nice shifters also,but i wanted this look.
Only difference in the mega shifter and the light weight truck shifter is the longer cover. And this shifter has adjustable plates to raise or lower the shifter.
Old 03-13-2012, 05:05 PM   #11
INSIDIOUS '86
Thank you John
My only issue is yes this works but r/n are very short I would rather have a reverse lock not a nuetral lock. Great shifter and I really like it but it isn't so great for a street strip vehicle
Old 03-13-2012, 05:07 PM   #12
77c10
77c10's Avatar
I had a Lokar double bend trans mount shifter in my truck that the PO installed. I took out the buckets and installed a bench seat. After that the shifter would hit the seat when trying to go into 1st gear. I bought a light truck Megashfiter at a swap meet brand new for $175.00 out the door. Put my Lokar on Ebay and it sold for nearly $190.00. I was very pleased with that aspect of it. Only thing I did not care for was the PO cut a hugh hole in the floor to mount the Lokar shifter.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 03-13-2012, 05:10 PM   #13
INSIDIOUS '86
Old 03-13-2012, 05:50 PM   #14
red rumbler
red rumbler's Avatar
how was the hookup? i have it just waiting to put it in.possible steps you took????
red rumbler is offline   Reply With Quote
Old 03-13-2012, 06:16 PM   #15
INSIDIOUS '86
You talking about the b&m or the lokar?
Old 03-13-2012, 10:48 PM   #16
red rumbler
sorry b&m also how long did it take?
Old 03-13-2012, 11:50 PM   #17
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
ive seen some VERY scary stuff happen with the B&M Megashifter and refuse to run one. however, if it works for you thats all that matters.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 03-14-2012, 12:02 AM   #18
355bullet
355bullet's Avatar
The B&M mega shifter has been on my nova for over ten years never have had an issue with it.
Old 03-14-2012, 12:09 AM   #19
355bullet
355bullet's Avatar
Couple pics i took when I installed it. Took couple of hours.
Its a tight fit because of the stock 4x4 shifter cover.
I wanted to keep it so I notch the other cover to clear it
I'll take another on of the cover tomorrow, i didn't realize the cable was covering it.
Old 03-14-2012, 12:12 AM   #20
355bullet
355bullet's Avatar
Dude! that looks kick ass!
Old 03-14-2012, 12:20 AM   #21
'79squared
'79squared's Avatar
Lokar looks cool also. But seems like it would be easy to over shift when running it hard up through the gears?
1979 SWB 350/350
Old 03-14-2012, 01:12 AM   #22
ivorton74
ivorton74's Avatar
looks pretty cool. i have a b&m hammer shifter im about to have installed in my truck. only issue is it seems to be kinda short...i mocked it up yesterday and i have to reach down to grab it. i was thinking maybe i can make a bracket to bring it up a bit so i can reach it.
ivorton74 is offline   Reply With Quote
Old 03-14-2012, 01:47 AM   #23
355bullet
355bullet's Avatar
Call B&M and ask if the adjustment brackets from the truck mega shifter will work. That way you can raise it.
Old 03-15-2012, 12:03 AM   #24
red rumbler
did you cut a fifth hole in the middle to run the shifter through? and did you hook wires up to the switches for reverse lights and safety switch? if so how was that and what did you do? sorry for all the questions i just dont want to tear my truck apart learning how to and how not to by screwing it up
Old 03-15-2012, 03:16 AM   #25
355bullet
355bullet's Avatar
yeah, you have to drill out one hole for the shifter cable. I didnt get pics of that thou. As for the switches i was in a rush to put it back together. I need to go back and trace for those wires to hook up.
The instructions are simple and straight foward. You should be fine.
