Old 03-13-2012, 04:51 AM   #1
jasonpickett
Emergency Brakes
I am build an ad truck. I was wondering if you guy are running emergency brakes. If so what different brake handles are you using.
Thanks,
Jason
jasonpickett is offline   Reply With Quote
Old 03-13-2012, 05:29 AM   #2
Mrcustom
Re: Emergency Brakes
I like the stock one. looks cool!
Mrcustom is offline   Reply With Quote
Old 03-13-2012, 10:05 AM   #3
zenchal26
zenchal26's Avatar
I'm building a 57 3100 and the old brake handle was in the way so I removed it. I also need a solution to the e-brake.
zenchal26 is offline   Reply With Quote
Old 03-13-2012, 12:34 PM   #4
justplainray
justplainray's Avatar
I'm in the middle of installing a MII front suspension (TCI) in my '56 and as of yet don't know what I'm doing about an E-brake either.
I would like to keep the OEM brake lever under the dash, does anyone know of a cable arrangement that will replace the OEM bell crank and rod arrangement?
justplain ray
justplainray is offline   Reply With Quote
Old 03-13-2012, 09:01 PM   #5
52 Rat
52 Rat's Avatar
I'm going to used a late 90's Honda e-brake handle assembly. I'm running rear disc and a S10 bench so I have room beside the seat between the door and seat. I've seen several this way and it makes a nice set up.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 03-13-2012, 09:57 PM   #6
c6_rob
c6_rob's Avatar
Im having the same dilemma. I have a disc brake conversion on the rear and I dont have the little "arm" that activates the parking brake. This part is impossible to find without buying a while new caliper. If any one had this Id be glad to pay you for it.
Then I started thinking of some type of Line Lock setup with a valve but that would keep the hydraulics pressured for an extended period of time. What do you think about that?
52 Chevy 3100
c6_rob is offline   Reply With Quote
Old 03-14-2012, 07:31 AM   #7
B_Hix
B_Hix's Avatar
I am using a Lokar e-brake kit, mounted to the right of the Lokar shifter - it is a bit of a reach but works for me.
http://www.lokar.com/product-pgs/eme...handbrake.html
in hindsight, this would probably be better for my truck - less of a reach -
Shifter -
http://www.summitracing.com/parts/LO...FQFgTAodT1d-wA
B_Hix is offline   Reply With Quote
Old 03-14-2012, 10:52 AM   #8
Russell Ashley
Russell Ashley's Avatar
Here's how I did mine using the stock handle. I converted it using cables and parts from Control Cable company. www.controlcable.com They are great folks to work with. I only had to fab a "hat" to hold the cable end at the firewall and modify the original pull rod a little. I could have used the original cables that came with my twelve bolt rear but I decided to just replace everthing while I was doing it. You can call Control Cables and they will fax or mail you a form that you put your measurements on and send back. They will make the cables per your measurements and specifications. Total cost was almost $175 so you might do it cheaper with junkyard parts but I wanted all new stuff.
Russell Ashley is offline   Reply With Quote
Old 03-14-2012, 10:56 AM   #9
justplainray
THANK YOU RUSSELL.
THAT IS EXACTLY WHAT I WAS LOOKING FOR.
justplainray
Old 03-15-2012, 08:31 PM   #10
Chevette
Chevette's Avatar
I remember seeing a mini rotor and caliper that mounts on the pinion shaft. You could use about any E-brake handle with it. Don't know if it's any good though.
Chevette is offline   Reply With Quote
Old 03-15-2012, 09:55 PM   #11
jasonpickett
Thanks for some info guys.
Old 03-15-2012, 10:09 PM   #12
av8tr33337
av8tr33337's Avatar
I'm planning to run something similar to this. I took the e brake system out of a dodge caravan (It's all sheathed cables)and it looks like I should be able to make it work.
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 03-15-2012, 10:50 PM   #13
sgtusmc
sgtusmc's Avatar
I used the stock brake handle as a exhaust cutout lever. Could be used as E-breaks to.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
