03-13-2012, 10:10 AM | #1 |
Pinion angle ??
Ok guys i need some info on pinion angle.
I done the rear flip on my 1 ton the poorboy way. I bought a pair of saddles and redrilled them to keep the driveshaft in the same location. The question is, i have never messed with pinion angle on a 2 piece shaft before. When i set it with the pinion down 2 degrees it sure looks like down alot. Where should i measure the angles at? Front of the rear shaft at the splines and on the pinion? Thanks
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
03-13-2012, 10:49 AM | #2 |
Re: Pinion angle ??
I asked same ? on engine drivetrain sec. and got lots of replys,just do a search on pinion angle,lots there
03-13-2012, 10:53 AM | #3 |
Re: Pinion angle ??
I did a search and didn't find anything, will try again.
03-13-2012, 11:47 AM | #4 |
At the body shop.
Re: Pinion angle ??
http://67-72chevytrucks.com/vboard/s...d.php?t=479179
" That didnt make it any newer " " Dont antique the equipment " |
03-13-2012, 12:12 PM | #5 |
Re: Pinion angle ??
Thanks. The spicer info helped.
03-13-2012, 12:19 PM | #6 |
At the body shop.
Re: Pinion angle ??
Glad it helped.
When i search i click on 67-72 side otherwise it searchs the web vs. Just here. Posted via Mobile Device
