Old 03-13-2012, 02:31 PM   #1
biohazardbill
Barn Door Adjustment
Having some issues.... converted from tailgate to barn doors on my burb. I see how to adjust front to back and up and down but not side to side. Upper left corner is hanging up a tad so I need to shift it towards the passenger side but see no way to do it.
Ideas?
biohazardbill is offline   Reply With Quote
Old 03-13-2012, 03:08 PM   #2
1963c-10
1963c-10's Avatar
Re: Barn Door Adjustment
Door adjustment can be done at two places; at the hinge straps to door panel and at the hinge cage to piller. Before adjustment is made, striker plates should be loosened and adjusted after door is located properly. The door can be moved in and out at the piller and the door can be moved up and down at the hinge to door panel. Move door as required and tighten bolts. Normal surface of door outer panel and body outer panels must align from flush to + or - .060" of being flush.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-13-2012, 03:14 PM   #3
biohazardbill
The striker plates were not in place yet, and I already stated what you have posted. The issue is i need to move the top of the driver side barn door toward the passenger side about 1/8 - 1/4 inch. The door is hitting the body. In and out and up and down still does not solve left to right.
Old 03-13-2012, 06:18 PM   #4
FreakyMalo
FreakyMalo's Avatar
What about some shims under the hinges?
66 Carryall
my photos
FreakyMalo is offline   Reply With Quote
Old 03-13-2012, 06:19 PM   #5
biohazardbill
I thought about that and did put some in as a temporary solution, however seeing if there is a right way to do it.
Old 03-13-2012, 08:48 PM   #6
rossboss
rossboss's Avatar
My suburban with barn doors had factory shims in a couple spots to line things up properly. So I believe shims are the correct way to make the adjustments needed.
rossboss is offline   Reply With Quote
Old 03-13-2012, 09:04 PM   #7
biohazardbill
Thanks, guess I will have to make some.
Old 03-13-2012, 10:10 PM   #8
tincan1966
tincan1966's Avatar
Both of my upper hinges seemed to be bent(had wide gap in between doors at top and narrow gap at bottom. Ended up having to "adjust" the hinges with a BFH. Probably not the preferred method, but was effective.
tincan1966 is offline   Reply With Quote
