Do it yourself bed liner
Did anybody use a bed liner for the cab floor in your truck? I want to use one of the do-it-yourself kits to line the floor before I go to paint and install carpet. No one will see. I am also thinking about lizard skin.
Re: Do it yourself bed liner
Ive seen a couple of people do it. Planned on it myself, but Im going to use the duplicolor kit...same one I used on my bed and you can get it by the quart or gallon.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Raptor liner is what I have found to work best, I have used on my jeeps etc.. and will be using it again on my 64. you can get the kit on e-bay and amazon for around 100-120 and it includes the gun to spray it. it is so much tougher than Rhino lining its not even funny.
Who Me?
This is mine. It has held up great!! The 1 gallon kit cost me about $90. I put down 2 coats and still have about 1/4 gal left. I also plan to redo my bed once its ready for it.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
![]() Join Date: Apr 2011
I'm planning on using Al's Liner. They also have a product called HNR (heat and Noise Reducer) that is less expensive than lizzard skin. Havn't used them yet--so I can't give any pro's or cons on the products.
C J 1959 APACHE 3100 1965 C20 1968 C10 short wide |
i like it! im gonna do that. are you gonna put any other insulation to protect from the engine?
Who Me?
Thats it for me.
I put the Henry's roof product in my cab, cheap, works good, and insulates good, 22.00 a gallon and you can't smell it once it cures. My friends call it an Oklahoma special. P.S. Born in Overbrook OK, 1951.
![]() Join Date: May 2007
a note on that stuff, dont let it touch your skin, it will take a week or so to wear off. use gloves and a long sleeve shirt.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
What is the Henrys roof stuff you mentioned.
Posted via Mobile Device |
figures i'd see this thread a day after i primered the floor,can i still use this stuff on top of the paint.
#12 | |
Senior Enthusiast
![]() This is probably the best shot I have of the texture: ![]()
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#13 | |
Who Me?
#14 |
#15 |
is that something you would find at Lowes or home depot?
#16 |
al's liner works good
#17 |
Who Me?
I found mine at a local auto parts store.
#18 |
Thanks for the feed back. I also was looking at the raptor kit. It seems not bad for $120. Do you think there is enough to shoot the side walls for a stepside bed and cab floor?
#19 |
there should be more than enough for your truck I had enough to completely do my jeep twice and had enough left to use on my kids wagon. you can also buy extra bottles raptor liner without the gun for like 20.00 apiece. If you look on ebay you can find the raptor for 102.00 right now. Oh and it is tintable if you want it body color. I have used herculiner and all of the others, Raptor just seems to be more durable and less sticky plus with spraying it on you can reach areas you can't reach by rolling.
#20 |
This is an interesting concept. But doesn't the cab just keep rusting underneath? I'd think you would want to do this you'd want to prep the heck out of it and take it down to shiny bare metal. Is that wrong?
#21 |
ive had good luck with this stuff. used it in a few cars to help kill sound also.
www.monstaliner.com |
#22 | |
hey.....smell my finger 64 nova wagon , 63 nova convertible |
#23 | |
As far as rusting underneath... Any time you can take down the active oxidation...as in scaling and delamming...down to wire wheel condition....and then completely encapsulating it (both sides..).....it'll last as long as it stays encapsulated. But, like y'all know...there's nuthin like white metal. But...as far as a little rusty color and paint bubble...take it down as far as ya can, and then prime it with a good two stage....and then cover...keeping in mind that with the newer epoxy primers, once it is prepped well and primed, ....all you need to do is protect that primer with a good product. Still, Nuthin like white metal.
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
#24 |
we used speedliner (similar to Al's from what i seen) on a bunch of cars underbodys works great. My last daily driver i used raptor on the under side and on the floor up the back and firewall and door insides. And MAN WAY BETTER THAN DYNAMAT!!!!!!!!! and was $150.00 total. doing same on the 65 im building now as soon as metal works done.
96 s10 static drop smooth and blue 99 silverado nothing stock layed out on 24s 65 c10 bagged patina driver http://www.myrideisme.com/Garage/az480 half-assed build thread http://67-72chevytrucks.com/vboard/s...=1#post5206828 |
#25 |
heres a link to a guy applying Raptor
