more pics of Bagged 1966 chevy trucks!!!
Would like to see pics and placement of front bags, brackets used or made with and or with out drop spindles. I have already installed bags in the rear and now getting ready to work on the front i have stock spindles it looks like just take the spring out and make some brackets out of flat stock to cover the spring pockets also do u cut factory bump stops off lower control arm to get lower if anyone has info and or some pics that would help me out thank you.
Who Me?
Re: more pics of Bagged 1966 chevy trucks!!!
Here is my 65. The bags replaced the coils. All I did was weld in a bag mount plate for the top and there ya go. No drop spindles and I could almost lay the frame.
Your truck should be the same. ![]() ![]() ![]()
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Thanks for the info are you running any bump stops? Also in the rear what did you do to get Ur truck that low did you cut the frame or just remove the factory bump stop and let it drop lower...
I have bolt in plates and bag cups up front and just bolted the bags to the trailing arms in the rear where the springs were and lowering blocks. i raised the bed wood up a 1 1/2 so the pumpkin on the rear end wouldnt hit the bed wood and would allow the c-notch to go all the way down.......i dont like how the front is so high when aired out so im going to cup the lower a-arms to mount the bags into the arm instead of on top the arm.......on the rear i just used some bag plates and no stand offs brackets, i just flipped the bags upside down and offset them on the trailing arms a little so i didnt have to drill the frame for the bag air fitting.... I saw how "61 FL Apache" mounted his into the lower spring hole but think that is really sketchy because the bag isnt supposed to rub anything!! Even tho "apache" said never had a problem that way...most bags have internal bump stops so if the air out before metal hits metal you should be fine, the rear c-notch comes with the bumpstops pictured below and i bought a set for the front when i cup the front arms(right now the front bags when aired out there is no need for separate bumpstops ...Ialso flipped the drivline carrier bearing mount to correct the driveline angle..After i cup the front a-arms i should be pretty low and used just the basic c-notch that bolts in and basic bag plates up front , nothing fancey or to expensive!
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 Last edited by losthope; 03-13-2012 at 09:21 PM. |
Sorry no pics , but on mine I used bump stops but did cut and shut them so they work as steering bumps as usual but clear the bags when aired out. On the rear I just shave the rubber bump stops so when aired out my exhaust can still clear brake lines. Wasn,t going for super low as this is my daily.
#6 | |
Who Me?
![]() ![]() The rears were installed when I got it, I did the fronts.
That's a pretty scarey looking notch.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
DiablosWeldingFabrication
Heres mine! Front has plates,cups,no shocks.. The back has frame mini c notch,blocks your basic setup
![]() ![]() 2.5 drop spindles and redid the lower control arms so the bags would set down in there to allow it to go all the way down
![]() bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
Front 2.5" spindles, raised 2.5" crossmember, cupped lower A arms, bagged. Rear is big notch 2" blocks and bags on stock traiiling arms with a custom rear crossmember to lay flat.
Not all the way aired out in the rear in pics. ![]() ![]() |
