05-04-2003, 05:57 PM | #1 |
spare tire
whats the deal with spare tires for these trucks? do you just throw them in the bed. i dont see the hardware for one under the rear.
thanks
I'm not a Muleskinner...... Dad gave me that CB handle when I was 8 so......... it pops in my head every now and then. |
05-04-2003, 06:02 PM | #2 |
Need more info. What model/year. They usally go under the rear unless you have a stepside. someone may have removed the hardware to put in a gas tank.
05-04-2003, 06:02 PM | #3 |
05-04-2003, 06:06 PM | #4 |
spare tire
oops. my truck is a 68 gmc fleetside 1/2 ton
thanks
05-04-2003, 07:09 PM | #5 |
Tasty Cakes!
There should be a place under the bed. Like ChevyKid said, someone may have removed the bracket to put in a gas tank. (even if they never put one in)
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
05-04-2003, 09:43 PM | #6 |
i installed min into the bed... its actually locked down. You couldn't do that unless someone messed up your bed with diamond plating tho.
05-04-2003, 09:48 PM | #7 |
Some came with the spare mounted in the bed. would have a bracket that mounted to the floor, and side of top railing. Had a slot for a carriarage head bolt that went thru a stud hole in the wheel to tighten the wheel to the bracket. Wheel stood upright .
69 GMC K10 ..some restoration required....still.. |
05-05-2003, 02:12 AM | #8 |
Southern Bowties
I got mine from the salvage yard for $20. Attaches to the frame under the rear of the bed. The one I got was from an '84 chev pu.
1972 Cheyenne 350/350 |
05-05-2003, 03:46 AM | #9 |
took my spare carrier off and just taking up room in the garage. started to clean it up to sell it then moved and haven't touched it since. maybe you guys will see it for sale soon. getting alot of stuff from my truck to sell that i don't want and figured you guys can use it.
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
05-05-2003, 10:29 AM | #10 |
I know on my old long bed had a metal braket that bolted inside the bed and it would hold my spare tire. My Blazer has an outside mount as you can see in the picture.
This is only my opinion and it is subject to change. 70 GMC Short box stepside Blown 388 Stroker 72 K/5 Blazer 350/SM465/205 |
05-05-2003, 01:36 PM | #11 |
Now the others dig........
Well, you can find a bracket from any fleetside or stepside Chevy/GMC up until 87. It bolts on with a long bolt that allows it to swing down from the frame above and behing the left rear shock. and then the bracket goes across at an angle at the end of the right side frame. The bracket has a figure 8 opening were the threaded lock thingy holds the bracket with tire up towards the frame. Confusing..sorry. But if it aint got a gas tank back there under the bed, just grab one from a yard, I have seen a couple, and actually found a 69 with an original one, I grabbed the first one I saw from an 82...damn if I would have kept walking, not that it matters they both work the same. Even if it is a little twisted, a vice and some brute force can get it sraight real easy. they are pretty cheap, well I only payed $8 for mine. Some places might rip you off big time.
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
05-05-2003, 02:03 PM | #12 |
newly minted old timer
here is mine... its the only way to go.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
05-05-2003, 02:04 PM | #13 |
2
05-05-2003, 05:05 PM | #14 |
i appreciate the response, i looked at trucks in the salvage yard for a tire carrier and never saw any of the hardware, thats why i wasnt sure how or if they made one. i see now they must be in high demand.
thanks
05-05-2003, 07:12 PM | #15 |
man...I knew I forgot someting....I forgot to paint mine!!!Damn.....well it ain't coming off anytime soon.
Hey Dave, what is up with that bumper bracket thingy,is that a trailer hitch or a bumper???? The only problem I had with mine was that the right side bolt was too short for my spare which was semi full size~31x11.5. So I found some threaded rods that my dad had laying around that coincedentaly were the same thread size as the original and I just chopped it a bit longer, bent the end to like a right angle and ran a square peice of steel with a nut and washer after it. And I think I ran another nut after I set it in the hole in the frame....and viola!!! Ran it through the hole on the bracket and tightened it, then just put a nut under it for safety.
05-05-2003, 07:16 PM | #16 |
Jackal2k9,
did you use that spray on bed liner from auto zone that comes in that long rattle can, or in those pints that you can spray on???? Thats simliar to wht I wanted to do to my truck...EVEN THE OVER HANGS!!!! I haven't finished yet though.
05-06-2003, 08:16 PM | #17 |
ive got th 50 dollar sprayer and the 50 dollar 1 gallon cans
i have donw a few bed liners for friends on the side... 150 bucks a piece and i make 50 bucks a bed. it came out nice. make sure that it if you get the dupont stuff you thin is with about 1/2 a pint of thinner. Check the spray after you add 1/2 and see if you like it... the more you add the smother and tougher the texture. HEY your in SAN ANTONIO!?!?! damn i thought i was the only one around with one of these that made it to this board. Tell me when you want it ill get my sprayer together and you can borrow it for a day or two. send me a pm if you want to borrow it. |
05-07-2003, 02:18 AM | #18 |
Jackal2k9
Hey, what part of town are you from...right now I'm in San Marcos for school and sumer work, but I'm originally from San Antonio on the southside. If you haven't read around, my engines dead....mechanic who overhauled it was a drunk...enough said. Only lasted three months with regular driving and weekend driving in and out of San Antonio/San Marcos. I don't wanna mess with fixing it though. gonna look for a rebuilt 350. Any word about City Motor Supply off of San Pedro??? Know any freinds that went that route for a rebuilt motor. I haven't done much searching but I think I'm gonna go with them when my dads get back from mexico. Me you and Dave should get together one weekend....talk trucks...grab a bite to eat. Or if any of you ever stop by the outlet malls in San Marcos, I work at the Candle Warehouse in the Tanger Mall I would love to get my bed finished finally, I used a crappy brush to brush it on and it looks pretty crappy, but it can be cleaned up and shot. I did my tailgate with that rattle can stuff and it came out ok. maybe we can find some time and you can help me out with it. Let me try to get my truck running before that.
