Old 03-13-2012, 09:55 PM   #1
RestoreAmerica
Front Brake Hoses
Hello,
I have a couple of 71/72's. I also have a 1969. I want to convert the 69 to disc brakes. How can I remove the hoses for reuse? I hate to spend $50 on a new set these look good. Any advice is appreciated.
RestoreAmerica is offline   Reply With Quote
Old 03-13-2012, 10:08 PM   #2
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: Front Brake Hoses
The brake hoses are diffrent for drums vs disc
you will have to change it out.
The hose for drum brakes screws directly into the back of the wheel cylinder were as the hose for the disc brake uses a banjo bolt to attach to the caliper
If you need a set of hoses I do actually have a pair that I will sell you
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 03-13-2012, 11:13 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Be aware that these hoses may look good from the outside but the inside swells when they're old and they keep the brake fluid from flowing freely through them. This happened to me and has happened to a lot of other owners with original hoses.
68gmsee is offline   Reply With Quote
Old 03-13-2012, 11:29 PM   #4
chevytruckluver
So true, I would never reuse a set of hoses that I didnt know about first hand.
the hoses I have extra here are new
Raybestos # BH380712 and BH380713
Trey
72 Short Step
Old 03-14-2012, 06:36 AM   #5
cdowns
cdowns's Avatar
$50 is cheap insurance compared to brake failure results// is your body worth it ??
