Old 03-14-2012, 04:11 AM   #1
Burb 71
Burb 71's Avatar
static drop question
I have a 71 c20 burb with a 292. I installed 2.5" spindles and 2"springs on the front. Not sure if anyone else has had this problem, but my passenger side is approximately .5"to .75"lower than the drivers side. Before I cut a approximately half a spring off anyone else have any ideas? Thanks
Burb 71 is offline   Reply With Quote
Old 03-14-2012, 10:32 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: static drop question
Did you measure it before you lowered it? Its not uncommon for these old trucks to be off to start with, but go undetected until we scrutinize them after lowering.
Beyond that, how long has it been lowered? does it need some miles on it to settle in? If not, take a look at the springs to ensure they are seated correctly.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-14-2012, 10:41 AM   #3
cdowns
cdowns's Avatar
b4 cutting i'd switch the spengs side to side
Old 03-14-2012, 08:44 PM   #4
Pro Performance
Pro Performance's Avatar
Ken had a good point.. To make sure both springs are seated properly, as that may cause one side to be higher.
Pro Performance is offline   Reply With Quote
Old 03-14-2012, 09:54 PM   #5
Burb 71
Burb 71's Avatar
Thanks for the responses. I will try swapping sides. I have checked the seat and it is OK. It has been this way for a while so they should have settled. I've been busy so just now getting to get back ti work on it.
