just bought 85 K-20 6.2L diesel
Just bought this truck.
Has 139k miles on the truck. Runs good but after it sits for 3 or 4 hours or overnight when you start it, it will start and die immediately and then you have to crank it and bleed a knob on the rectangular box on the firewall then do again a few times and it will start and run fine after the 3rd time. Leak in a fuel line? Anyone ever dealt with this issue? Nice truck and planning to use it on the farm but dont want to have to bleed it every time it sits for a night etc. |
Re: just bought 85 K-20 6.2L diesel
That's a beautiful truck... and that's a realy truck not like what they put out today man.. that thing is nice
Rust is better than rice. ![]() |
Thanks for the compliment! Just bought it to take and keep on the farm so I dont get stuck heading to the hunting spots. Probably live in the garage and come out 10-12 times a year.
Just here to tinker
![]() Join Date: Jun 2008
What rectangular box are talking about? The fuel filter? We need more info or pics on what you're talking about. What did the previous owner say about it?
Truck looks beautiful.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
I think it is the filter. Mounted next to the a/c evap coil ox and has snap spring's like the way a master cylinder lid is held on. Has a clear or white cap on the top left that bleeds it.
Previous owner showed me how to make it start by bleeding it after cranking the engine and said he thought it was a leaking fuel line. I have never owned one of these so do not know where to start. Sorry no other pictures immediate but can take more if you think it would help. Thanks Tim |
Well you're getting air in the system somewhere near the engine bay and the fuel is draining back to the tank. I would start looking around where you bleed it. It could even be the thing you bleed it with thats letting air back in.
Nice truck by the way!
Semi professional heavy equipment operator Amateur mechanic |
Thanks man! Appreciate the compliment.
I will start looking for the culprit! |
You haven't noticed any puddles of fuel or anything have you? If there are no leaks then I would look for places air could get in. Either way it's losing its prime and there's a bad hose, line or connection somewhere. If it's not around that bleeder you are talking about, just check out the rest of the fuel system from the tank to the engine.
No I havent but it is on gravel so might not be evident.
I just bought it so havent had any time to study the situation yet. Could it be from that filter box (dont know the technical term) with the bleeder to the engine, or would it be from the box with bleeder back to the tank or all of the above? Appreciate your input! Tim |
Now THAT'S a truck.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch |
#11 | |
Good to know!
I will have to get under and start looking. |
#13 |
![]() Join Date: Oct 2006
Also check out The Diesel Place. LOTS of very good info there on the 6.2. I know I love mine. I think I have read to get rid of the 'box' type filter and go with the older screw-on filter.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
#14 |
BTW, that is a VERY nice truck you got.
#15 |
Thanks Lance!
That isnt a bad idea at all. That box filter thingey which never having owned one of these is alien to me anyway, looks like a problem waiting to happen. |
#16 |
If it has dual tanks check the tank switch under the truck on the passenger side. When I first converted my truck to a 6.2 my switch was letting air in and I couldn't keep it running. Once I got the switch swapped out with another one I had laying around it starts right up.
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
#17 |
Box filter works fine, nee to check the o rings on the screws. There's a thread on it over at DP.
Remember, keep an eye on temp and oil, check those oil cooler lines (LH rear of block).
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
#18 |
Gentleman Jim Driver
Your leak is most likely out the back of the fuel filter base from the differential pressure sensor. They leaked enough that GM/Stanadyne stopped putting the sensor in that filter in about 1988 or so. Get a different housing that doesn't have the sensor.
I'm on my 4th 6.2 diesel truck and 3 of them have leaked there. The one that doesn't is an 82 and has the old round filters... The square filter works great otherwise and is very quick and easy to change. I wouldn't get rid of it...
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
#19 |
#20 |
Nice truck! That's exactly what I've been looking for. I even posted my diesel '85 Jimmy for trade for a truck like that. Great find.I just can't find one around here.
Definitely air getting in there. Look for seepage.It could be anywhere...in front of or behind the filter/water separator. Does it start right up after bleeding or still crank a while? Definitely look for seepage from tank to injectors,but when an injector pump goes it will get hard to start. But,it's all the time.
#21 |
Thanks all!
I will be checking all those things as soon as I have time to get on it. All great information that I appreciate! Tim |
#22 |
What Hump?
Really nice truck need more pics though
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
#23 |
Will try to do that soon. Might take a while though b/c I am tied up with some training and have been crazy busy.
#24 |
A problem I had was where the injector return line T's in to the hard line (right behind the alternator). The little hose coming off the injector went bad and made my burb difficult to start. The hose was an old cloth covered rubber POS. It would fire up then immediately die. Once I replaced that hose and double checked all the other connections...found a loose hose clamp too...the beast would fire right up.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
#25 |
Chevys Kick A$$
Awesome looking truck looks preety clean and well taken care of. Good luck on the air issues hope it's an easy fix for ya!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
