03-14-2012, 11:43 AM | #1 |
______________
WTB: OEM Bed Sheetmetal Needed
I'm in need of some oem bed sheetmetal from a donor truck. Hopefully someone has a bed that is in pretty bad shape that won't mind cutting me out a couple of sections for rust repair and gas filler shaving.
First I need a 5"x5" bed floor section that includes both rails on the bed floor - the lower and upper ridges. Second I need a 10"x10" section of a bedside. Needs to have the same contour as the picture, as I'm filling a bed fuel fill. I need to be able to PayPal for both pieces - no snail mail. I'm trying to get these repaired ASAP. My zip is 94596 for shipping. Thanks in advance. |
03-14-2012, 01:58 PM | #2 |
Re: WTB: OEM Bed Sheetmetal Needed
I think I can help you with that. Id like to get $25 for the two pieces, I know thier not big but I will burn up at least 1 or maybe 2 cutting wheels to get them out plus the time to do it and box it and take it to the post office. I should be able to get both in a mediam flat rate box for $11.35. If that sounds ok LMK and I can PM my payment info to you and I can get it in the mail. So to be clear, would that be 10'' up from say that lower body line,and jut a 5 x 5 piece of bed floor not nesasaraly from that spot but just to include 2 ribs one high and one low,correct? Frank
03-14-2012, 02:04 PM | #3 | |
______________
Thanks Frank. The 10" section from the bedside is actually only 1.5" up from the body line. Not the trim piece (because those will vary from 67-72) but the actual body line where it transitions from the lower panel to the side. In the picture there is a black line and rust colored lines that run parrallel to the molding and the fuel door - that line. PM me your payment details and I'll get you a payment now. |
03-14-2012, 02:25 PM | #4 |
SLOW POKE
In the first pic , this is right behind the drivers side front of bed correct ? If so , are you measuring from the post over 5'' & down 5'' from inside front bed panel or 5x5 from edges of bed floor metal ?
68 SHORT-BED-STEP-SIDE piece by piece ,
day by day , I will restore this truck , before the 100th anniversary !!! |
03-14-2012, 07:10 PM | #5 |
PM sent thanks Frank
03-14-2012, 07:16 PM | #6 |
______________
03-14-2012, 11:44 PM | #7 |
Thanks I'll get it out.
