Old 03-14-2012, 11:51 AM   #1
thetucks
New door weather seals
I ordered new door weather seals from classic parts. I put them on today and you have to slam the door for them to latch. Is there something im doing wrong?
thetucks is offline   Reply With Quote
Old 03-14-2012, 12:25 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: New door weather seals
They need time to "break in"
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-14-2012, 01:04 PM   #3
thetucks
but should I have to really slam it?
Old 03-14-2012, 01:11 PM   #4
CC69Rat
CC69Rat's Avatar
Someone may have adjusted the door latch at one point in the truck's life, pulling it in because the seals were bad maybe? Now that they are new the door latch is just that much tighter..
.. just a best guess.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-14-2012, 01:14 PM   #5
thetucks
I have actually had both doors off because I just repainted the truck. but the doors all line up with the body like they are suppose to. if I move them out then they will stick out from the body.
Old 03-14-2012, 02:02 PM   #6
RenoKeene
Florida Edition
RenoKeene's Avatar
It takes very minor changes to gain max effects on these doors. I ended up shimming my hinges off the cab with A/C compressor shims (very thin) and making very slight adjustments to the latch plates on the cab. It takes a while but if you work with small adjustments you will hit it.
I suggest you tape all the door edges with blue painters tape to protect the paint from getting chipped. I also used wd paint stirrers to set my panel gaps as I went along.
Lets see if I have any pics...
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 03-14-2012, 05:56 PM   #7
lil hoodlum
lil hoodlum's Avatar
I installed some new door weather seals back in November. I am still having to slam the passenger side door.
So yeah, you might be slamming those doors for a little bit.
Good luck!
Keith
lil hoodlum is offline   Reply With Quote
Old 03-14-2012, 06:01 PM   #8
Dunenutt
Newbee
Dunenutt's Avatar
http://www.soffseal.com/store/main.a...tail&item=9009
Not cheap, but the door will close!
Dunenutt is offline   Reply With Quote
Old 03-14-2012, 07:10 PM   #9
hockeyjerk1
hockeyjerk1's Avatar
My seals are slowly getting there after 9mths, the passenger will close nicely now and the drivers is getting easier, patience!
hockeyjerk1 is offline   Reply With Quote
Old 03-14-2012, 07:18 PM   #10
TigerDMD
GMC Paul's snap on door seals are the way to go. Just put them on - no adjustments and the door shuts fine
TigerDMD is offline   Reply With Quote
Old 03-14-2012, 08:18 PM   #11
Tim Christian
Tim Christian's Avatar
I agree with Dunenutt. I only use soffseal on all my builds and have never had any problems like that.
Tim Christian is offline   Reply With Quote
Old 03-14-2012, 10:10 PM   #12
rkn463
rkn463's Avatar
I have the same problem but I think it was self induced on mine. They had already been replaced at some point in the trucks life so when I pulled the old ones off I put the glue on the flat outside of the raised rib (if that makes sense) just like the previous ones had been done. I have to slam the ever-living-hell out of them to get them to latch even with the striker plate adjusted completely out. I think both the previous installer and i got it wrong - I believe the glue should be on the rib. Where mine is glued is causing the rubber to have to fold up instead of compressing. I already pulled parts of it loose and it is better. I may be completely off base here... if someone knows where the glue should be I would appreciate the advice.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
