Old 03-14-2012, 01:33 PM   #1
ripper70
ripper70's Avatar
Filler tube venting
Is it necessary to use a vent on the actual filler tube when installing a blazer tank or can i eliminate that vent and just use the other 2 little ones on tank? If its a must to use a filler tube vent then where do i find 1 and how do i connect it to the style of neck im using. Here is the neck im using.http://www.overtons.com/modperl/prod...B&merchID=4006
ripper70 is offline   Reply With Quote
Old 03-14-2012, 02:43 PM   #2
ripper70
ripper70's Avatar
Re: Filler tube venting
Forgot to add its a Blazer tank conversion for my 70 k-20...They moved me to blazer forum...oops
Old 03-14-2012, 03:38 PM   #3
DaBigKahuna
DaBigKahuna's Avatar
Subscribed!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=513812
DaBigKahuna is offline   Reply With Quote
Old 03-14-2012, 03:57 PM   #4
jasons
not enough hours in the day
jasons's Avatar
You could get by without the vent, but it would be slow to fill the tank. The air in the tank has to escape as fast as the gas is going in.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
& piles of spare parts
jasons is offline   Reply With Quote
Old 03-14-2012, 04:15 PM   #5
Bentblazer
Bentblazer's Avatar
Might want to check this out: http://67-72chevytrucks.com/vboard/s...d.php?t=187860 #5
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
